10-06-2018, 16:55 | #5401 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | samsung J320F FRP Code: Brand : Samsung Model : J320F Operation : Reset FRP Searching for Phone...Found Port: : COM282 : SAMSUNG Mobile USB Modem #181 Checking for Device...Found [Normal Mode] Reading Phone Information...OK Software: : J320FXXU0AQA2/J320FOXE0AQA2//J320FXXU0AQA2 Init Download Mode...OK Waiting for phone in Download Mode...OK Port: : COM46 : SAMSUNG Mobile USB Modem #10 Reading Data from Phone...Done Chipset : SPRD8735 [HiSpeed] Loading Data...OK Resetting FRP Data...OK Closing Session...Done ---------------- IMPORTANT ---------------- Wait for phone to turn on completely. goto Menu > Settings > Backup and Reset and do Factory data Reset. Operation Finished. UltimateFRP Ver. 0.3 |
The Following User Says Thank You to technomak For This Useful Post: |
10-06-2018, 17:38 | #5402 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Lenovo TB-8504X FRP removed Code: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 8D38F8EB0CBB95080DCEDFBE45E94AC61F6F97294B272A65DBFB3329E55CB750 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8917_ddr.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LENOVO Lenovo TB-8504X [msm8937] Software : TB-8504X_S000029_170703_ROW, TB-8504X_S000029_170703_ROW [2017年 07月 03日 星期一 12:12:17 CST] Android Ver. : 7.1.1 Patch Level : 2017-06-01 Resetting FRP Lock......Done Operation Finished. |
10-06-2018, 19:00 | #5403 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Samsung s6 edge [g925a] drk repair done Port : COM112 : USB Serial Port (COM112) Baud Rate : 115200 (Auto) Device : Samsung Operation : Device Root Key Fix Opening Port... OK Checking For Phone... OK Entering Test Mode... OK Reading Phone Information... OK Model : SM-G925A Cust Code : ATT SW Ver. : FA50_G925AUCU7ARA1 Unique No. : 04157DF483333F2D IMEI(1) : 35952106091728 IMEI(2) : Empty MSL Authorization Skipped Checking Device Root Key Status... Not Good Fixing Device Root Key.... Done Verifying Device Root Key... Done Rebooting Phone... Done Port Closed. Operation Finished. Elapsed Time: 01:11 [Module Ver. 5.2] Log Saved to Logs\181006_183106.log |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
10-08-2018, 06:51 | #5406 (permalink) |
No Life Poster Join Date: May 2011 Location: WeChat : Razib_Dits
Member: 1582197 Status: Offline Sonork: Whatapps : Razibbsl Thanks Meter: 808 | Device : Vivo V11 Pro Operation : Vivo Format FS / FRP Reset Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 04007300 OPK_DATA : A103747D6F285B7FDDA476A5E985F67EB8D73574FB572BC345 35197B5417B2E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8976_017]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1804 Software : OPM1.171019.011 release-keys, eng.compil.20180907.204412 [Fri Sep 7 20:44:12 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-08-01 Formatting userdata...Done Resetting FRP Lock...Done Wipe cache / userdata from Recovery and reboot. First startup may take 2-5 minutes. Operation Finished. QcFire Ver. 3.0 |
The Following User Says Thank You to SoniaTel For This Useful Post: |
10-08-2018, 07:09 | #5407 (permalink) |
Crazy Poster Join Date: Dec 2014 Location: Malaysia
Member: 2318529 Status: Offline Thanks Meter: 71 | Oppo A57 frp and format one click done Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 2729EC539F0C70FA21C67CD1B8C249998B3D85E480BE31DB27 277ABB926ECC2D Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_009]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO CPH1701 [msm8937] Software : CPH1701EX_11_A.33_180508, eng.root.20180508.104025 [Tue May 8 10:43:34 CST 2018] Android Ver. : 6.0.1 Patch Level : 2018-05-05 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.0 |
The Following User Says Thank You to biewolf23 For This Useful Post: |
10-08-2018, 11:04 | #5408 (permalink) |
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | XT 1766 FRP unlocked Code: Brand : Motorola Model : XT1766 Operation : Reset FRP Searching for Device in FastBoot Mode...OK Reading Phone Information...OK Model : XT1766 Boot Ver. : moto-msm8920-BB.07 Baseband : M8920_15000.280.06.58.02R PERRY_NA_CA_CUST Software : Blur_Version.26.11.59.sperry_sprint.sprint.en.US IMEI : xxxxxxxxxx CPU : MSM8920 RAM : 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=1F EMMC : 16GB SAMSUNG QE63MB RV=08 PV=03 FV=0000000000000003 Setting Factory Mode...OK Searching Network Interface...Found Connecting to device...OK Model : Moto E (4) Bootloader : 0xBB07 Baseband : M8920_15000.280.06.58.02R PERRY_NA_CA_CUST Build : Blur_Version.26.11.59.sperry_sprint.sprint.en.US Android : 7.1.1 Searching Network Interface...Found Connecting to device...OK Model : Moto E (4) Bootloader : 0xBB07 Baseband : M8920_15000.280.06.58.02R PERRY_NA_CA_CUST Build : Blur_Version.26.11.59.sperry_sprint.sprint.en.US Android : 7.1.1 Retetting FRP...OK Searching for Device in FastBoot Mode...OK Removing Factory Mode...OK Operation Finished. UltimateFRP Ver. 0.3 |
10-08-2018, 15:30 | #5409 (permalink) |
Freak Poster Join Date: Apr 2016 Location: GSM Forum Age: 27
Member: 2559216 Status: Offline Thanks Meter: 220 | Xiaomi Redmi 4x Reset Mi account done By qcfire 3.0 Xiaomi Redmi 4x Reset Mi account done By qcfire 3.0 Br |
The Following User Says Thank You to Riz_Mobile For This Useful Post: |
10-08-2018, 15:32 | #5410 (permalink) |
Member: 2559216 Status: Offline Thanks Meter: 220 | xiaomi Redmi note 5 pro Reset FRP done By Qcfire 3.0 xiaomi Redmi note 5 pro Reset FRP done By Qcfire 3.0 Br |
10-08-2018, 15:33 | #5411 (permalink) |
Member: 2559216 Status: Offline Thanks Meter: 220 | Xiaomi Mi A1 Reset FRP Done By Qcfire 3.0. Xiaomi Mi A1 Reset FRP Done By Qcfire 3.0. Br |
10-08-2018, 15:54 | #5412 (permalink) |
Member: 2559216 Status: Offline Thanks Meter: 220 | Oppo A57 Format+FRP Done in one click By qcfire 3.0 Oppo A57 Format+FRP Done in one click By qcfire 3.0 Br |
10-08-2018, 17:48 | #5413 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Laputa
Member: 941825 Status: Offline Sonork: 100.1584774 Thanks Meter: 34 | Device : Xiaomi Redmi S2 Operation : Bootloader Unlock/Relock Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM18) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi S2 Software : OPM1.171019.011, V9.6.2.0.OEFMIFD [Thu Jul 5 11:31:21 WIB 2018] Android Ver. : 8.1.0 Patch Level : 2018-06-01 Reading Data...Done Bootloader : Locked Preparing Data...Done Writing Data...Done Operation Finished. QcFire Ver. 3.0 |
The Following User Says Thank You to redpig For This Useful Post: |
10-09-2018, 08:02 | #5414 (permalink) |
Member: 2559216 Status: Offline Thanks Meter: 220 | Lenovo K33a42 Format+FRP Done in one click By Qcfire 3.0 Lenovo K33a42 Format+FRP Done in one click By Qcfire 3.0 Br |
10-09-2018, 08:03 | #5415 (permalink) |
Member: 2559216 Status: Offline Thanks Meter: 220 | Xiaomi Redmi Note 4 Reset Mi account Done By Qcfire 3.0 Xiaomi Redmi Note 4 Reset Mi account Done By Qcfire 3.0 Br |
