04-21-2019, 09:58 | #6691 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | Operation : Reset FRP CPU : MT6735 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : Symphony Manufacturer : Symphony Model : P6 PRO Prod. Name : P6_PRO Device : P6_PRO Board : P6_PRO Platform : mt6735 Android Ver. : 5.1 Display ID : P6PRO_RAM_V6 Patch Level : 2015-11-30 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.8] |
The Following User Says Thank You to sajid01913 For This Useful Post: |
04-21-2019, 10:22 | #6692 (permalink) |
Member: 821462 Status: Offline Thanks Meter: 833 | Twin Mos Tab MQ703W FRP Remove Done Operation : Reset FRP CPU : MT6580 Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usb2ser.sys, 3.0.1504.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : K706 Manufacturer : roco Model : MQ703W Prod. Name : MQ703W Device : K706 Board : K706 Platform : mt6580 Android Ver. : 7.0 Display ID : SW01_H_MQ703W_20171026 Patch Level : 2017-08-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.8] |
04-21-2019, 10:23 | #6693 (permalink) |
04-21-2019, 14:23 | #6694 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | vivo Y51 Pattern Lock Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D5C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo Y51 [msm8916] Software : LRX22G release-keys, eng.compiler.20171201.164954 [Fri Dec 1 16:53:32 CST 2017] Android Ver. : 5.0.2 Patch Level : 2017-11-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
04-21-2019, 14:24 | #6695 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Mmx Q4202 Hang @ Logo Code: Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [splash.img] -> [splash] ...Done Writing [sec.dat] -> [sec] ...Done Writing [boot.img] -> [boot] ...Done Writing [system_1.img] -> [system] ...Done Writing [system_2.img] -> [system] ...Done Writing [system_3.img] -> [system] ...Done Writing [system_4.img] -> [system] ...Done Writing [system_5.img] -> [system] ...Done Writing [system_6.img] -> [system] ...Done Writing [system_7.img] -> [system] ...Done Writing [system_8.img] -> [system] ...Done Writing [system_9.img] -> [system] ...Done Writing [system_10.img] -> [system] ...Done Writing [system_11.img] -> [system] ...Done Writing [system_12.img] -> [system] ...Done Writing [system_13.img] -> [system] ...Done Writing [system_14.img] -> [system] ...Done Writing [system_15.img] -> [system] ...Done Writing [system_16.img] -> [system] ...Done Writing [system_17.img] -> [system] ...Done Writing [system_18.img] -> [system] ...Done Writing [system_19.img] -> [system] ...Done Writing [system_20.img] -> [system] ...Done Writing [system_21.img] -> [system] ...Done Writing [system_22.img] -> [system] ...Done Writing [system_23.img] -> [system] ...Done Writing [system_24.img] -> [system] ...Done Writing [system_25.img] -> [system] ...Done Writing [system_26.img] -> [system] ...Done Writing [system_27.img] -> [system] ...Done Writing [system_28.img] -> [system] ...Done Writing [system_29.img] -> [system] ...Done Writing [system_30.img] -> [system] ...Done Writing [system_31.img] -> [system] ...Done Writing [system_32.img] -> [system] ...Done Writing [system_33.img] -> [system] ...Done Writing [system_34.img] -> [system] ...Done Writing [system_35.img] -> [system] ...Done Writing [system_36.img] -> [system] ...Done Writing [system_37.img] -> [system] ...Done Writing [system_38.img] -> [system] ...Done Writing [system_39.img] -> [system] ...Done Writing [system_40.img] -> [system] ...Done Writing [system_41.img] -> [system] ...Done Writing [system_42.img] -> [system] ...Done Writing [system_43.img] -> [system] ...Done Writing [system_44.img] -> [system] ...Done Writing [system_45.img] -> [system] ...Done Writing [system_46.img] -> [system] ...Done Writing [system_47.img] -> [system] ...Done Writing [system_48.img] -> [system] ...Done Writing [system_49.img] -> [system] ...Done Writing [persist_1.img] -> [persist] ...Done Writing [cache_1.img] -> [cache] ...Done Writing [cache_2.img] -> [cache] ...Done Writing [cache_3.img] -> [cache] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [userdata_1.img] -> [userdata] ...Done Writing [userdata_2.img] -> [userdata] ...Done Writing [userdata_3.img] -> [userdata] ...Done Writing [userdata_4.img] -> [userdata] ...Done Writing [userdata_5.img] -> [userdata] ...Done Writing [userdata_6.img] -> [userdata] ...Done Writing [userdata_7.img] -> [userdata] ...Done Writing [userdata_8.img] -> [userdata] ...Done Writing [userdata_9.img] -> [userdata] ...Done Writing [userdata_10.img] -> [userdata] ...Done Writing [userdata_11.img] -> [userdata] ...Done Writing [userdata_12.img] -> [userdata] ...Done Writing [userdata_13.img] -> [userdata] ...Done Writing [userdata_14.img] -> [userdata] ...Done Writing [userdata_15.img] -> [userdata] ...Done Writing [userdata_16.img] -> [userdata] ...Done Writing [userdata_17.img] -> [userdata] ...Done Writing [userdata_18.img] -> [userdata] ...Done Writing [userdata_19.img] -> [userdata] ...Done Writing [userdata_20.img] -> [userdata] ...Done Writing [userdata_21.img] -> [userdata] ...Done Writing [userdata_22.img] -> [userdata] ...Done Writing [userdata_23.img] -> [userdata] ...Done Writing [userdata_24.img] -> [userdata] ...Done Writing [userdata_25.img] -> [userdata] ...Done Writing [userdata_26.img] -> [userdata] ...Done Writing [userdata_27.img] -> [userdata] ...Done Writing [userdata_28.img] -> [userdata] ...Done Writing [userdata_29.img] -> [userdata] ...Done Writing [userdata_30.img] -> [userdata] ...Done Writing [userdata_31.img] -> [userdata] ...Done Writing [userdata_32.img] -> [userdata] ...Done Writing [userdata_33.img] -> [userdata] ...Done Writing [userdata_34.img] -> [userdata] ...Done Writing [userdata_35.img] -> [userdata] ...Done Writing [userdata_36.img] -> [userdata] ...Done Writing [userdata_37.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 4.1 |
04-21-2019, 14:26 | #6696 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Lenovo A6020a46 Hang @ Logo Code: Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Invalid response from device! Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B09000 [8936] 01000100 OPK_DATA : 5F5DBD11259E7F99680B3D60E74EC73BDD5387694EA6D96CBF808A68A7369E82 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8936_004]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8936, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [splash.img] -> [splash] ...Done Writing [sec.dat] -> [sec] ...Done Writing [boot.img] -> [boot] ...Done Writing [system_1.img] -> [system] ...Done Writing [system_2.img] -> [system] ...Done Writing [system_3.img] -> [system] ...Done Writing [system_4.img] -> [system] ...Done Writing [system_5.img] -> [system] ...Done Writing [system_6.img] -> [system] ...Done Writing [system_7.img] -> [system] ...Done Writing [system_8.img] -> [system] ...Done Writing [system_9.img] -> [system] ...Done Writing [system_10.img] -> [system] ...Done Writing [system_11.img] -> [system] ...Done Writing [system_12.img] -> [system] ...Done Writing [system_13.img] -> [system] ...Done Writing [system_14.img] -> [system] ...Done Writing [system_15.img] -> [system] ...Done Writing [system_16.img] -> [system] ...Done Writing [system_17.img] -> [system] ...Done Writing [system_18.img] -> [system] ...Done Writing [system_19.img] -> [system] ...Done Writing [system_20.img] -> [system] ...Done Writing [system_21.img] -> [system] ...Done Writing [system_22.img] -> [system] ...Done Writing [system_23.img] -> [system] ...Done Writing [system_24.img] -> [system] ...Done Writing [system_25.img] -> [system] ...Done Writing [system_26.img] -> [system] ...Done Writing [system_27.img] -> [system] ...Done Writing [system_28.img] -> [system] ...Done Writing [system_29.img] -> [system] ...Done Writing [system_30.img] -> [system] ...Done Writing [system_31.img] -> [system] ...Done Writing [system_32.img] -> [system] ...Done Writing [system_33.img] -> [system] ...Done Writing [system_34.img] -> [system] ...Done Writing [system_35.img] -> [system] ...Done Writing [system_36.img] -> [system] ...Done Writing [system_37.img] -> [system] ...Done Writing [system_38.img] -> [system] ...Done Writing [system_39.img] -> [system] ...Done Writing [persist_1.img] -> [persist] ...Done Writing [cache_1.img] -> [cache] ...Done Writing [cache_2.img] -> [cache] ...Done Writing [cache_3.img] -> [cache] ...Done Writing [cache_4.img] -> [cache] ...Done Writing [cache_5.img] -> [cache] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [userdata_1.img] -> [userdata] ...Done Writing [userdata_2.img] -> [userdata] ...Done Writing [userdata_3.img] -> [userdata] ...Done Writing [userdata_4.img] -> [userdata] ...Done Writing [userdata_5.img] -> [userdata] ...Done Writing [userdata_6.img] -> [userdata] ...Done Writing [userdata_7.img] -> [userdata] ...Done Writing [userdata_8.img] -> [userdata] ...Done Writing [userdata_9.img] -> [userdata] ...Done Writing [userdata_10.img] -> [userdata] ...Done Writing [userdata_11.img] -> [userdata] ...Done Writing [userdata_12.img] -> [userdata] ...Done Writing [userdata_13.img] -> [userdata] ...Done Writing [userdata_14.img] -> [userdata] ...Done Writing [userdata_15.img] -> [userdata] ...Done Writing [userdata_16.img] -> [userdata] ...Done Writing [userdata_17.img] -> [userdata] ...Done Writing [userdata_18.img] -> [userdata] ...Done Writing [userdata_19.img] -> [userdata] ...Done Writing [userdata_20.img] -> [userdata] ...Done Writing [userdata_21.img] -> [userdata] ...Done Writing [userdata_22.img] -> [userdata] ...Done Writing [userdata_23.img] -> [userdata] ...Done Writing [userdata_24.img] -> [userdata] ...Done Writing [userdata_25.img] -> [userdata] ...Done Writing [userdata_26.img] -> [userdata] ...Done Writing [userdata_27.img] -> [userdata] ...Done Writing [userdata_28.img] -> [userdata] ...Done Writing [userdata_29.img] -> [userdata] ...Done Writing [userdata_30.img] -> [userdata] ...Done Writing [userdata_31.img] -> [userdata] ...Done Writing [userdata_32.img] -> [userdata] ...Done Writing [userdata_33.img] -> [userdata] ...Done Writing [userdata_34.img] -> [userdata] ...Done Writing [userdata_35.img] -> [userdata] ...Done Writing [userdata_36.img] -> [userdata] ...Done Writing [userdata_37.img] -> [userdata] ...Done Writing [userdata_38.img] -> [userdata] ...Done Writing [userdata_39.img] -> [userdata] ...Done Writing [userdata_40.img] -> [userdata] ...Done Writing [userdata_41.img] -> [userdata] ...Done Writing [userdata_42.img] -> [userdata] ...Done Writing [userdata_43.img] -> [userdata] ...Done Writing [userdata_44.img] -> [userdata] ...Done Writing [userdata_45.img] -> [userdata] ...Done Writing [userdata_46.img] -> [userdata] ...Done Writing [userdata_47.img] -> [userdata] ...Done Writing [userdata_48.img] -> [userdata] ...Done Writing [userdata_49.img] -> [userdata] ...Done Writing [userdata_50.img] -> [userdata] ...Done Writing [userdata_51.img] -> [userdata] ...Done Writing [userdata_52.img] -> [userdata] ...Done Writing [userdata_53.img] -> [userdata] ...Done Writing [userdata_54.img] -> [userdata] ...Done Writing [userdata_55.img] -> [userdata] ...Done Writing [userdata_56.img] -> [userdata] ...Done Writing [userdata_57.img] -> [userdata] ...Done Writing [userdata_58.img] -> [userdata] ...Done Writing [userdata_59.img] -> [userdata] ...Done Writing [userdata_60.img] -> [userdata] ...Done Writing [userdata_61.img] -> [userdata] ...Done Writing [userdata_62.img] -> [userdata] ...Done Writing [userdata_63.img] -> [userdata] ...Done Writing [userdata_64.img] -> [userdata] ...Done Writing [userdata_65.img] -> [userdata] ...Done Writing [userdata_66.img] -> [userdata] ...Done Writing [userdata_67.img] -> [userdata] ...Done Writing [userdata_68.img] -> [userdata] ...Done Writing [userdata_69.img] -> [userdata] ...Done Writing [userdata_70.img] -> [userdata] ...Done Writing [userdata_71.img] -> [userdata] ...Done Writing [userdata_72.img] -> [userdata] ...Done Writing [userdata_73.img] -> [userdata] ...Done Writing [userdata_74.img] -> [userdata] ...Done Writing [userdata_75.img] -> [userdata] ...Done Writing [userdata_76.img] -> [userdata] ...Done Writing [userdata_77.img] -> [userdata] ...Done Writing [userdata_78.img] -> [userdata] ...Done Writing [userdata_79.img] -> [userdata] ...Done Writing [userdata_80.img] -> [userdata] ...Done Writing [userdata_81.img] -> [userdata] ...Done Writing [userdata_82.img] -> [userdata] ...Done Writing [userdata_83.img] -> [userdata] ...Done Writing [userdata_84.img] -> [userdata] ...Done Writing [userdata_85.img] -> [userdata] ...Done Writing [userdata_86.img] -> [userdata] ...Done Writing [userdata_87.img] -> [userdata] ...Done Writing [userdata_88.img] -> [userdata] ...Done Writing [userdata_89.img] -> [userdata] ...Done Writing [userdata_90.img] -> [userdata] ...Done Writing [userdata_91.img] -> [userdata] ...Done Writing [userdata_92.img] -> [userdata] ...Done Writing [userdata_93.img] -> [userdata] ...Done Writing [userdata_94.img] -> [userdata] ...Done Writing [userdata_95.img] -> [userdata] ...Done Writing [userdata_96.img] -> [userdata] ...Done Writing [userdata_97.img] -> [userdata] ...Done Writing [userdata_98.img] -> [userdata] ...Done Writing [userdata_99.img] -> [userdata] ...Done Writing [userdata_100.img] -> [userdata] ...Done Writing [userdata_101.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 4.1 Code: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1B09000 [8936] 01000100 OPK_DATA : 5F5DBD11259E7F99680B3D60E74EC73BDD5387694EA6D96CBF808A68A7369E82 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8936_004]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8936, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LENOVO Lenovo A6020a46 [msm8916] Software : A6020a46_S105_161124_ROW, A6020a46_S105_161124_ROW [2016年 11月 24日 星期四 22:44:03 CST] Android Ver. : 5.1.1 Patch Level : 2016-10-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
04-21-2019, 14:28 | #6697 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Xiaomi Redmi Note 4 Pattern + Frp +Mi Account Removed Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : AL1512-mido-build-20180531213711, V9.5.11.0.NCFMIFA [Thu May 31 21:37:09 WIB 2018] Android Ver. : 7.0 Patch Level : 2018-05-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 Code: Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 4 [msm8953] Software : AL1512-mido-build-20180531213711, V9.5.11.0.NCFMIFA [Thu May 31 21:37:09 WIB 2018] Android Ver. : 7.0 Patch Level : 2018-05-01 Resetting Mi Account Data...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.1 |
04-21-2019, 14:29 | #6698 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Xiaomi Redmi S2 Pattern Lock Code: Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi S2 Software : OPM1.171019.011, V10.2.2.0.OEFMIXM [Thu Mar 14 20:25:53 WIB 2019] Android Ver. : 8.1.0 Patch Level : 2019-03-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
04-21-2019, 14:30 | #6699 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | vivo 1724 Pattern Lock Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4FFF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1724 Software : OPM1.171019.011 release-keys, eng.compil.20190117.161833 [Thu Jan 17 16:18:33 CST 2019] Android Ver. : 8.1.0 Patch Level : 2019-01-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.1 |
04-21-2019, 14:32 | #6700 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Xiaomi Redmi 4X Mi Account Code: Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] Software : N2G47H, V10.1.1.0.NAMMIFI [Wed Nov 14 19:06:32 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-10-01 Resetting Mi Account Data...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.1 |
04-21-2019, 19:28 | #6701 (permalink) |
Freak Poster Join Date: Apr 2017
Member: 2702540 Status: Offline Thanks Meter: 50 | reset frp condor plume p8 lite Code: Operation : Reset FRP CPU : MT6737T Storage : EMMC DA : MTK_AllInOne_DA.bin [MTK_AllInOne_DA_v3.3001.2017-12-29.16:29] Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : PreLoader USB VCOM Port (COM5) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Driver: MediaTek Inc., usbser.sys, 2.0.0.0 Syncing with Target... Reading Partition Table... Reading Device Information... Brand : condor Manufacturer : SPA Condor Electronics Model : PGN610 Prod. Name : PGN610 Device : PGN610 Board : PGN610 Platform : mt6737t Android Ver. : 7.0 Display ID : PGN610 Patch Level : 2017-10-05 Userdata is ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [Ver. 1.8] |
The Following User Says Thank You to mabo13 For This Useful Post: |
04-22-2019, 10:45 | #6702 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Derbent
Member: 2516133 Status: Offline Thanks Meter: 55 | LG K430DS flash done Port : COM196 : LGE Mobile USB Serial Port (COM196) Baud Rate : 115200 - Auto Device : LG *Automatic* Operation : Write Firmware Opening Port...OK Reading Information...OK Model : LG-K430ds PID : VS05S160916003823 IMEI : 357717074067313 Firmware : K43011i Factory Ver. : LGK430dsAT-00-V11i-CIS-XX-FEB-11-2017+0 LAF Ver. : 1.1 Chipset : mt6753 Operator : GLOBAL Country : COM Memory ID : Q316AB Capacity : 14,56 GB Battery : 50% MemType : eMMC Sector : 512 Reading Partition Table...OK Setting Parameters...Done Analyzing KDZ Firmware... Loading DZ Firmware...Loaded 45 Partition(s) Model : LG-K430 Version : K430V11t Sector Size : 0x0200 Finalizing Parameters...Done Formatting [userdata]...Done Formatting [encrypt]...Done Writing 01 of 45 [preloader]...Done Writing 02 of 45 [pgpt]...Done Writing 03 of 45 [lk]...Done Writing 04 of 45 [laf]...Done Writing 05 of 45 [boot]...Done Writing 06 of 45 [recovery]...Done Writing 07 of 45 [logo]...Done Writing 08 of 45 [secro]...Done Writing 09 of 45 [tee1]...Done Writing 10 of 45 [tee2]...Done Writing 11 of 45 [cust]...Done Writing 12 of 45 [factory]...Done Writing 13 of 45 [efuse]...Done Writing 14 of 45 [system]...Done Writing 15 of 45 [system]...Done Writing 16 of 45 [system]...Done Writing 17 of 45 [system]...Done Writing 18 of 45 [system]...Done Writing 19 of 45 [system]...Done Writing 20 of 45 [system]...Done Writing 21 of 45 [system]...Done Writing 22 of 45 [system]...Done Writing 23 of 45 [system]...Done Writing 24 of 45 [system]...Done Writing 25 of 45 [system]...Done Writing 26 of 45 [system]...Done Writing 27 of 45 [system]...Done Writing 28 of 45 [system]...Done Writing 29 of 45 [system]...Done Writing 30 of 45 [system]...Done Writing 31 of 45 [system]...Done Writing 32 of 45 [system]...Done Writing 33 of 45 [system]...Done Writing 34 of 45 [system]...Done Writing 35 of 45 [system]...Done Writing 36 of 45 [system]...Done Writing 37 of 45 [system]...Done Writing 38 of 45 [system]...Done Writing 39 of 45 [system]...Done Writing 40 of 45 [system]...Done Writing 41 of 45 [system]...Done Writing 42 of 45 [system]...Done Writing 43 of 45 [system]...Done Writing 44 of 45 [OP]...Done Writing 45 of 45 [sgpt]...Done Reading Partition Table...OK Formatting [mpt]...Done Finalizing Parameters...Done Rebooting Device....Done Operation Finished. Time taken: 09:06 [UltimateLG v0.5] |
The Following User Says Thank You to ramsay05 For This Useful Post: |
04-22-2019, 16:29 | #6703 (permalink) |
Member: 2516133 Status: Offline Thanks Meter: 55 | Redmi Note 4x flash done Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [adspso.bin] -> [dsp] ...Done Writing [fs_image.tar.gz.mbn.img] -> [fsg] ...Done Writing [sec.dat] -> [sec] ...Done Writing [splash.img] -> [splash] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [system.img ] -> [system]...Done Writing [cache.img ] -> [cache]...Done Writing [persist.img ] -> [persist]...Done Writing [lksecapp.mbn] -> [lksecapp] ...Done Writing [lksecapp.mbn] -> [lksecappbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [cust.img ] -> [cust]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 4.1 |
