12-27-2015, 10:06 | #181 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | mts m151 repair security done Code: Port : COM26 : Qualcomm HS-USB Diagnostics 9004 (COM26) Baud Rate : 921600 Device : Karbonn B121 Operation : Write MEID Opening Port... OK Reading Information... OK Compile : Jan 15 2015 21:01:24 Release : Apr 24 2010 23:00:00 Hw Ver. : W027_KK9 ESN : 00000000 MEID : 00000000000000 Build : Q1110-W027_KK9A_M151_MTS-3375 Writing MEID A10000476-----... OK New ESN : 80E11--- New MEID : A1000047------ Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.4] Log Saved to Logs\151227_131834.log Listing Available Ports... Done |
The Following User Says Thank You to rehmani For This Useful Post: |
12-27-2015, 10:13 | #182 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g361h country unlock done without root Code: Port : COM80 : SAMSUNG Mobile USB Modem #11 Baud Rate : 115200 Device : Samsung G360H Operation : Unlock Opening Port... OK Reading Information... OK Model : SM-G361H IMEI : 3542020786----- Version Info : G361HXXU0AOG3 : G361HOJV0AOG1 : G361HXXU0AOF8 : G361HXXU0AOG3 Preparing Phone... OK Reading Lock Status... OK Status : SIM Locked* Phone May Be Hard Locked, Unlock May Not Work Reading Lock Levels.. OK Lock Level [0] : Locked Lock Level [1] : Unlocked Lock Level [2] : Unlocked Lock Level [3] : Unlocked Lock Level [4] : Unlocked Resetting Lock Codes... Done UnFreeze : 00712621 Level[1] : 83626762[Locked] Level[2] : 00000000[Unlocked] Level[3] : 00000000[Unlocked] Level[4] : 00000000[Unlocked] Level[5] : 00000000[Unlocked] Port Closed. Operation Finished. Elapsed Time: 00:12 Module Ver. [1.5] Log Saved to Logs\151227_143952.log |
12-27-2015, 11:49 | #183 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lava m143 flash done Code: Port : COM26 : Qualcomm HS-USB Diagnostics 9004 (COM26) Baud Rate : 921600 Device : Lava M141 Operation : Flash [Emergency] Opening Port... OK Preparing Phone... OK Sending Bootloader... OK Executing Bootloader... OK Initializing Flash Chip... OK Chip Name : SPANSION S71VS128R Chip Size : 16 MB File Name : lava m143 K232_Y10_15_04_18_19_07_48.bin Fw. Size : 16 MB Writing Firmware... OK Resetting Phone... OK Port Closed. Operation Finished. Time Taken: 07:18 Module Ver. [1.4] Log Saved to Logs\151227_161233.log |
12-29-2015, 05:51 | #184 (permalink) |
No Life Poster Join Date: Dec 2007 Location: coimbatore
Member: 653676 Status: Offline Thanks Meter: 301 | HUWAI E315 UNLOCK SUCCESSFULLY ----------------------------------------- Port : COM286 : FC - Application Interface (COM286) Baud Rate : 921600 Device : Huawei EC315 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Oct 25 2014 12:42:13 Release : Mar 05 2014 02:00:00 Hw Ver. : SCAUTHZ3 ESN : 8049F934 MEID : A000004FD70CAD Hw. Type : EC315-1CE1EC315M Ver.A Firmware : HWEC315DT03 Dashboard : HiLink12.001.12.08.113 Flash Code : 64190249 Lock Status : Locked RUIM Mode : NV Only Unlocking Modem... OK Trying to Read SPC... Err 0x01 Failed to Read! Using Default SPC [000000]... OK Changing RUIM Mode Setting... OK RUIM Mode : RUIM Only Port Closed. Operation Finished. Time Taken: 00:02 Module Ver. [1.4] Log Saved to Logs\151229_101936.log |
The Following User Says Thank You to rimboy_cbe For This Useful Post: |
12-29-2015, 09:33 | #185 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | mts s505 repair security done Code: Port : COM15 : USB Serial Port (COM15) Baud Rate : 115200 Device : S100 Operation : Write MEID Opening Port... OK Reading Information... Compile : Nov 12 2008 09:46:44 Release : Oct 24 2006 13:00:00 Hw Ver. : CT_C321+ ESN : 00000000 MEID : 00000000000000 Unlocking Security... Failed Build : QSC6010-SCNRZ-CT_C321+_RBTN01NV1.0.0B03 Software : ----- Detected User Code : 0000 Writing MEID A10000558-----... OK New ESN : 8067D--- New MEID : A10000558----- Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.4] Log Saved to Logs\151229_135438.log Code: Port : COM15 : USB Serial Port (COM15) Baud Rate : 115200 Device : S100 Operation : Write MEID Opening Port... OK Reading Information... Compile : Nov 12 2008 09:46:44 Release : Oct 24 2006 13:00:00 Hw Ver. : CT_C321+ ESN : 00000000 MEID : 00000000000000 Unlocking Security... Failed Build : QSC6010-SCNRZ-CT_C321+_RBTN01NV1.0.0B03 Software : ----- Detected User Code : 0000 Writing MEID A10000558-----... OK New ESN : 80C83--- New MEID : A10000558----- Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.4] Log Saved to Logs\151229_135951.log |
12-29-2015, 12:52 | #186 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lg rd3500 unlock done Code: Port : COM13 : LGE CDMA USB Serial Port (COM13) Baud Rate : 38400 - Auto Device : LG RD3500 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Dec 27 2007 16:27:15 Release : Dec 27 2007 23:00:00 Hw Ver. : RD350F08 ESN : 8097A--- MEID : A100004B1----- Model : RD3500 Software : F08 Preparing Data... OK Setting Offline Mode... OK Security Unlock... OK Setting Download Mode... OK Preparing Bootloader... OK Sending Bootloader... OK Executing Bootloader... OK Erasing Flash Memory... OK Erasing Flash Memory... OK Writing Flash Memory... OK Writing Flash Memory... OK Resetting Phone... OK Port closed. Operation Finished. Time Taken: 00:26 Module Ver. [1.4] Log Saved to Logs\151229_172011.log |
12-29-2015, 15:31 | #187 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | zte s165 write efs done Code: Port : COM11 : ZTE CDMA Handset Diagnostics Interface (COM11) Baud Rate : 921600 Device : ZTE S165 Operation : Flash EFS Opening Port... OK Reading Information... OK Compile : Feb 26 2013 15:53:03 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.S1 ESN : 00000000 MEID : 00000000000000 Unlocking Security... OK Build : V.MTS.S165.B04 Soft Ver. : SSTL_S165_SP1_RBTL40NV1.0.0B02 Detected : S165 User Code : 0000 Setting Download Mode... OK Waiting for Reconnect... OK Initializing Flash Chip... OK Flash Chip : SPANSION S71VS064RB0 Chip Size : 8 MB Firmware : S165 UNLOCK FILE.BIN Fw. Size : 8 MB Writing EFS Area... OK Resetting Phone... OK Port Closed. Operation Finished Time Taken: 01:17 Module Ver. [1.4] Log Saved to Logs\151229_194042.log |
12-30-2015, 07:20 | #188 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung n7000 format done wihout adb Code: Port : COM131 : SAMSUNG Mobile USB Modem #10 Baud Rate : 115200 Device : Samsung A300H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : GT-N7000 IMEI : 3596160494----- Version Info : N7000DXLR5 : N7000OLBLR2 : N7000DXLR1 : N7000DXLR5 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:11 Module Ver. [1.5] Log Saved to Logs\151230_114839.log |
12-30-2015, 07:48 | #189 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung t211 format done wihout adb Code: Port : COM133 : SAMSUNG Mobile USB Modem #11 Baud Rate : 115200 Device : Samsung A300H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : SM-T211 IMEI : 3576420512----- Version Info : T211XXANA4 : T211ODDANA2 : T211XXANA2 : T211XXANA4 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:10 Module Ver. [1.5] Log Saved to Logs\151230_121754.log |
12-31-2015, 09:20 | #190 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | mts s505 repair security done Code: Port : COM4 : USB Serial Port (COM4) Baud Rate : 115200 Device : S100 Operation : Write MEID Opening Port... OK Reading Information... Compile : Nov 12 2008 09:46:44 Release : Oct 24 2006 13:00:00 Hw Ver. : CT_C321+ ESN : 00000000 MEID : 00000000000000 Unlocking Security... Failed Build : QSC6010-SCNRZ-CT_C321+_RBTN01NV1.0.0B03 Software : ----- Detected User Code : 0000 Writing MEID A10000558-----... OK New ESN : 8094B--- New MEID : A1000055------ Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.4] Log Saved to Logs\151231_133615.log |
12-31-2015, 10:48 | #191 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | zte s165 write efs repair security done write efs Code: Port : COM11 : ZTE CDMA Handset Diagnostics Interface (COM11) Baud Rate : 921600 Device : ZTE S165 Operation : Flash EFS Opening Port... OK Reading Information... OK Compile : Apr 10 2012 15:17:30 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.S1 ESN : 32973085 MEID : 00000000000000 Unlocking Security... OK Build : V.MTS.S165.B04 Soft Ver. : SSTL_S165_SP_RBTL40NV1.0.0B03 Detected : S165 User Code : 0000 Setting Download Mode... OK Waiting for Reconnect... OK Initializing Flash Chip... OK Flash Chip : SPANSION S71VS064RB0 Chip Size : 8 MB Firmware : S165 UNLOCK FILE.BIN Fw. Size : 8 MB Writing EFS Area... OK Resetting Phone... OK Port Closed. Operation Finished Time Taken: 01:16 Module Ver. [1.4] Log Saved to Logs\151231_151752.log Code: Port : COM11 : ZTE CDMA Handset Diagnostics Interface (COM11) Baud Rate : 921600 Device : S165 Operation : Write MEID Opening Port... OK Reading Information... Compile : Apr 10 2012 15:17:30 Release : Apr 24 2009 24:00:00 Hw Ver. : V.MTS.S1 ESN : 00000000 MEID : 00000000000000 Unlocking Security... OK Build : V.MTS.S165.B04 Software : SSTL_S165_SP_RBTL40NV1.0.0B03 Detected : S165 User Code : 0000 Writing MEID A0000037C-----... OK New ESN : 8003C--- New MEID : A0000037------ Port Closed. Operation Finished. Time Taken: 00:01 Module Ver. [1.4] Log Saved to Logs\151231_151812.log |
12-31-2015, 11:37 | #192 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g313h format done wihout adb Code: Port : COM17 : SAMSUNG Mobile USB Modem #4 Baud Rate : 115200 Device : Samsung G360H Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : SM-G313H IMEI : 3528400625----- Version Info : G313HDDU0ANJ4 : G313HODD0ANJ1 : G313HDDU0ANJ1 : G313HDDU0ANJ4 Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:08 Module Ver. [1.5] Log Saved to Logs\151231_160537.log |
12-31-2015, 14:59 | #193 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | lg rd6100 unlock done Code: Port : COM22 : LGE Mobile USB Serial Port (COM22) Baud Rate : 38400 - Auto Device : LG RD6100 Operation : Unlock Opening Port... OK Reading Information... OK Compile : Jan 17 2008 21:16:23 Release : Jan 17 2008 23:00:00 Hw Ver. : RD610F04 ESN : 9663C--- MEID : A000000C2----- Model : RD6100 Software : F04 Preparing Data... OK Setting Offline Mode... OK Security Unlock... OK Setting Download Mode... OK Preparing Bootloader... OK Sending Bootloader... OK Executing Bootloader... OK Erasing Flash Memory... OK Erasing Flash Memory... OK Writing Flash Memory... OK Writing Flash Memory... OK Resetting Phone... OK Port closed. Operation Finished. Time Taken: 00:26 Module Ver. [1.4] Log Saved to Logs\151231_192359.log |
01-02-2016, 10:58 | #194 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung g350e format done wihout adb Code: Port : COM30 : SAMSUNG Mobile USB Modem #6 Baud Rate : 115200 Device : Samsung G350E Operation : Format Phone (AT) Opening Port... OK Reading Information... OK Model : SM-G350E IMEI : 3546990665----- Version Info : G350EXXU0ANFA : G350EOJV0ANF7 : G350EXXU0ANF8 : G350EXXU0ANFA Formatting Phone... OK Phone Will Reboot When Done. Port Closed. Operation Finished. Elapsed Time: 00:14 Module Ver. [1.5] Log Saved to Logs\160102_152654.log |
01-02-2016, 14:40 | #195 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | samsung j361h country unlock done without adb Code: Port : COM39 : SAMSUNG Mobile USB Modem #8 Baud Rate : 115200 Device : Samsung G360H Operation : Unlock Opening Port... OK Reading Information... OK Model : SM-G361H IMEI : 3542020786----- Version Info : G361HXXU0AOG3 : G361HOJV0AOG1 : G361HXXU0AOF8 : G361HXXU0AOG3 Preparing Phone... OK Reading Lock Status... OK Status : SIM Locked* Phone May Be Hard Locked, Unlock May Not Work Reading Lock Levels.. OK Lock Level [0] : Locked Lock Level [1] : Unlocked Lock Level [2] : Unlocked Lock Level [3] : Unlocked Lock Level [4] : Unlocked Resetting Lock Codes... Done UnFreeze : 00712621 Level[1] : 83626762[Locked] Level[2] : 00000000[Unlocked] Level[3] : 00000000[Unlocked] Level[4] : 00000000[Unlocked] Level[5] : 00000000[Unlocked] Port Closed. Operation Finished. Elapsed Time: 00:10 Module Ver. [1.5] Log Saved to Logs\160102_190606.log |
