11-19-2018, 08:22 | #5601 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | oppo a37f patten read by umt Operation : Read Pattern Lock Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO A37f [msm8916] Software : A37fEX_11_171209, 1480422943 [Sat Dec 9 16:58:03 CST 2017] Android Ver. : 5.1.1 Patch Level : 2017-12-01 USERDATA : Normal Reading Pattern Data...Done Pattern : 36258 Operation Finished. QcFire Ver. 3.3 2950 |
The Following User Says Thank You to djj007 For This Useful Post: |
11-19-2018, 08:22 | #5602 (permalink) |
Member: 2643730 Status: Offline Thanks Meter: 1,115 | oppo a71 cph1801 patten lock removed by umt Device : Oppo A71 (CPH1801) Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 557BAC65705B8A8303276B9FBB8FD533DBB33EA9E55BF80B47 647B8549C170B9 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_015]...Done Executing Loader...OK Formatting Userdata...Done Disconnect phone and hold Power Button to reset. Operation Finished. QcFire Ver. 3.3 |
11-19-2018, 08:30 | #5603 (permalink) |
Member: 2643730 Status: Offline Thanks Meter: 1,115 | vivo v7+ patten+frp removed by umt Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1716 [msm8953] Software : N2G47H release-keys, eng.compil.20180528.223559 [Mon May 28 22:35:59 CST 2018] Android Ver. : 7.1.2 Patch Level : 2018-05-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
11-19-2018, 08:49 | #5604 (permalink) |
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Redmi note 3 mi account disable done by umt Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1009B00 [8976] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8976_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8976, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 3 [msm8952] Software : MMB29M, V8.1.6.0.MHOMIDI [Sun Jan 22 19:59:30 CST 2017] Android Ver. : 6.0.1 Patch Level : 2016-12-01 Reading Data... Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished. QcFire Ver. 3.3 |
11-19-2018, 09:00 | #5605 (permalink) |
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Vivo y55s pin+frp removed by umt Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1610 [msm8937] Software : MMB29M release-keys, eng.compiler.20180716.180224 [Mon Jul 16 18:07:16 CST 2018] Android Ver. : 6.0.1 Patch Level : 2018-07-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
11-19-2018, 11:04 | #5606 (permalink) |
Freak Poster Join Date: Oct 2017 Location: Mardan Pakistan Age: 38
Member: 2768168 Status: Offline Thanks Meter: 42 | J111F FRP reset with one click. Model : J111F Operation : FRP Reset (Format UD) Searching for Phone...Found Port: : COM10 : SAMSUNG Mobile USB Modem #3 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : SPRD8735 [HiSpeed] Loading Data...Done Sending Data...Done Closing Session...Done Operation Finished. Elapsed Time 00:11 Module Ver. 0.1 LOG Saved to !Logs\181119_145821.log |
The Following User Says Thank You to Abdul Basit GSM For This Useful Post: |
11-19-2018, 11:04 | #5607 (permalink) |
11-19-2018, 11:47 | #5608 (permalink) |
Crazy Poster Join Date: Dec 2014 Location: Malaysia
Member: 2318529 Status: Offline Thanks Meter: 71 | Samsung note 5 binary 5 frp done. Device: Any Samsung Operation: Exynos (UFS) FRP Reset Port: COM50 : SAMSUNG Mobile USB Modem #8 Checking for Device... Found [Normal Mode] Reading Phone Information... OK Model: SM-N9208 IMEI: 355320072315271 Software: N9208XXS5CRH1/N9208OLB3CQJ1/N9208XXU5CRH1/N9208XXS5CRH1 Init Download Mode... OK Port: COM5 : SAMSUNG Mobile USB Modem Reading Data from Phone... Done Chipset: LSI7420 [HiSpeed] Port : COM10 : USB Serial Port (COM10) Please keep holding VOL Down + Power buttons together... Phone Found, LEAVE Buttons! Preparing Device... Done Erasing FRP Data... Done Erasing Samsung Account Data... Done Erasing EE Data... Done Operation Finished. Elapsed Time: 01:31 [Ultimate Samsung Flasher v1.4] |
