02-17-2019, 10:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: india
Member: 1911060 Status: Offline Sonork: [email protected] Thanks Meter: 303 | redmi 6 pro mi account failed umt please help umt teamm Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8953_ddr (1).mbn]...Done Executing Loader...OK Detecting Chip Type...OK VIP Enabled / Auth Enabled Device! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+PGRhdGE+PGxvZyB2YWx1ZT0iRVJST1I6IE9ubHkgbm9wIGFu ZCBzaWcgdGFnIGNhbiBiZSByZWNldmllZCBiZWZvcmUgYXV0aG VudGljYXRpb24uIiAvPjwvZGF0YT48P3htbCB2ZXJzaW9uPSIx LjAiIGVuY29kaW5nPSJVVEYtOCIgPz48ZGF0YT48cmVzcG9uc2 UgdmFsdWU9Ik5BSyIgLz48L2RhdGE+ Please use correct loader and check USB port / cable. Operation Finished. |
02-17-2019, 10:12 | #2 (permalink) |
Member: 1911060 Status: Offline Sonork: [email protected] Thanks Meter: 303 | Device : Xiaomi Redmi Note 6 Pro Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.7 |
02-17-2019, 11:36 | #4 (permalink) | |
No Life Poster Join Date: Aug 2012 Location: Bali-Indonesia
Member: 1800628 Status: Offline Thanks Meter: 941 | Quote:
sometimes need little trick hold testpoint until sending loader. if sending loader say done release TP | |
The Following User Says Thank You to Deni's For This Useful Post: |
02-19-2019, 05:11 | #5 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: searching Age: 31
Member: 2424314 Status: Offline Thanks Meter: 731 | Quote:
02-19-2019, 05:34 | #6 (permalink) | |
Freak Poster Join Date: Jan 2015 Location: Dhaka Bangladesh
Member: 2333595 Status: Offline Sonork: wwwsonork.com Thanks Meter: 120 | select storage type EMMC Quote:
qc v 3.7 redmi note 6 pro some device select manual storage for work select EMMC storage your problem will solved inshallah | |
02-20-2019, 05:04 | #8 (permalink) |
No Life Poster Join Date: Sep 2017 Location: INDONESIA
Member: 2755295 Status: Offline Thanks Meter: 198 | http://forum.gsmhosting.com/vbb/f970...-more-2550712/ the redmi 6 pro and the redmi note 6 pro are different |
02-20-2019, 05:40 | #9 (permalink) |
Member: 1911060 Status: Offline Sonork: [email protected] Thanks Meter: 303 | yes you are right both diffrent redmi 6 pro msm 8953 and redmi note msm 8996 |
02-22-2019, 05:50 | #10 (permalink) |
Member: 1911060 Status: Offline Sonork: [email protected] Thanks Meter: 303 | please help umt team Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. |
02-22-2019, 07:06 | #11 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Quote:
for now use remote service | |
