05-30-2021, 07:48 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: KOLKATA INDIA
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Redmi 6A imei repair problem Model : Redmi 6A Operation : Repair IMEI Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM4 Port Name: MediaTek USB Port_V1632 (COM4) Path: \\?\usb#vid_0e8d&pid_0003#5&2108ad5d&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : xiaomi Manufacturer : Xiaomi Model : Redmi 6A Prod. Name : cactus Device : cactus Build Date : Wed Mar 11 18:11:29 WIB 2020 Build Flavor : cactus-user Build Desc. : cactus-user 9 PPR1.180610.011 V11.0.7.0.PCBMIXM release-keys Android Ver. : 9 Display ID : SW_S98506AE1_V009_M13_XM_C3C_USR Patch Level : 2020-03-01 Platform : MT6765 Board : cactus Platform : mt6765 Userdata is ENCRYPTED Reading NV IMEI Data... Failed to Seek! NV IMEI1 : NV IMEI2 : NVRAM Saved as: C:\UMTool\UltimateMTK\NVRAM\NV___mt6765___210530_1 21601.nvf Detected IMEI Algo 0 New IMEI1 : 860435043433413 New IMEI2 : 860435043433421 Preparing IMEI data [2]... NV_OFFSET is unknown! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.3] phone says unable to get imei |
05-30-2021, 10:45 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,452 | You are doing it wrong. First, make hardware modification if you want to repair both. Then goto MTK One Click, and tick on Patch Mode / Format NVRAM, when software ask for format, click Yes. Now use META new method and you will be done. Br, UMT |
06-01-2021, 03:51 | #3 (permalink) | |
Member: 207734 Status: Offline Sonork: 100.1612198 Thanks Meter: 141 | Quote:
Brand : Xiaomi Model : Redmi 6A Operation : Repair IMEI Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM4 Port Name: MediaTek USB Port_V1632 (COM4) Path: \\?\usb#vid_0e8d&pid_0003#5&2108ad5d&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM4) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Flashing Failed! Disconnect cable and Power ON phone. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Brand : xiaomi Manufacturer : Xiaomi Model : Redmi 6A Prod. Name : cactus Device : cactus Build Date : Wed Mar 11 18:11:29 WIB 2020 Build Flavor : cactus-user Build Desc. : cactus-user 9 PPR1.180610.011 V11.0.7.0.PCBMIXM release-keys Android Ver. : 9 Display ID : SW_S98506AE1_V009_M13_XM_C3C_USR Patch Level : 2020-03-01 Platform : MT6765 Board : cactus Platform : mt6765 Userdata is ENCRYPTED Reading NV IMEI Data... Failed to Seek! NV IMEI1 : NV IMEI2 : NVRAM Saved as: C:\UMTool\UltimateMTK\NVRAM\NV___mt6765___210601_0 81941.nvf Detected IMEI Algo 0 New IMEI1 : 860435043433413 New IMEI2 : 860435043433421 Preparing IMEI data [2]... NV_OFFSET is unknown! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.3] | |
06-01-2021, 06:59 | #4 (permalink) | |
Operation : IMEI Reapir [META (New)] Checking for existing META ports... No existing META port found. Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM4 Port Name: MediaTek USB Port_V1632 (COM4) Path: \\?\usb#vid_0e8d&pid_0003#5&2108ad5d&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Found MediaTek USB Port_V1632 (COM4) on COM4 Device Path : usb\vid_0e8d&pid_0003&rev_0100 Mode : BROM Rebooting to META mode... Waiting for phone in META mode... Found MediaTek USB VCOM (Android) (COM21) on COM21 Device Path : \\?\usb#vid_0e8d&pid_200e#5&2108ad5d&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Configuring Communication Channel... Reading phone information... CPU : MT6765 SW Ver. : MOLY.LR12A.R2.MP.V24.32.P71 HW Ver. : WINGTECH_O1MP6_K62V1_64_BSP_HW IMEI1 : 151515151515151 IMEI2 : 151515151515151 Reading data from phone... Repairing IMEI1 to 860435043433413... Repairing IMEI2 to 860435043433421... Syncing Data... Operation Finished. [UltimateMTK Ver. 4.3] | |
The Following User Says Thank You to srworld For This Useful Post: |
09-14-2021, 12:51 | #6 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | What is the problem? help please Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... Disable Auth Success Found MediaTek USB Port_V1632 (COM359) on COM359 Device Path : usb\vid_0e8d&pid_0003&rev_0100 Mode : BROM Rebooting to META mode... Waiting for phone in META mode... Found MediaTek USB VCOM (Android) (COM93) on COM93 Device Path : \\?\usb#vid_0e8d&pid_200e&mi_00#6&1dd30aff&0&0000# {f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} Configuring Communication Channel... Reading phone information... Failed to read META data! Failed to read META data! Failed to read META data! Failed to read META data! Operation Failed. [UltimateMTK Ver. 4.3] |
