09-11-2020, 19:38 | #1 (permalink) |
Freak Poster Join Date: Oct 2012 Location: transilvania
Member: 1820429 Status: Offline Thanks Meter: 57 | redmi nore 6 pro fail Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...Not Found! DebugData : BAAAABAAAAANAAAAAQAAAA== Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 Operation : Xiaomi Boot Patch Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...OK Blob : NTI2NTYzNkY2NzZFNjk3QTY1NjQyMDQxNzQ3NDcyNjk2Mjc1Nz Q2NTIwNEU3NTZENjI2NTcyMjAzNTM2MjAyODI3NTQ2MTcyNjc2 NTc0NEU2MTZENjUyNzI5MjA3NzY5NzQ2ODIwNzY2MTZDNzU2NT IwMjc3MjY1NzEyNzIwNzQ3OTcwNjUyMDY5NzMyMDI3NzMyNz== Requesting UMT Server for Auth Data...SERVER_UNDER_MAINTENANCE Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 |
09-12-2020, 05:28 | #3 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | i tried to unlock boot loader frp Format I already lost count that I have tried so hard, the same result Operation : Xiaomi Boot Patch Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...OK Blob : NTI2NTYzNkY2NzZFNjk3QTY1NjQyMDQxNzQ3NDcyNjk2Mjc1Nz Q2NTIwNEU3NTZENjI2NTcyMjAzNTM2MjAyODI3NTQ2MTcyNjc2 NTc0NEU2MTZENjUyNzI5MjA3NzY5NzQ2ODIwNzY2MTZDNzU2NT IwMjc3MjY1NzEyNzIwNzQ3OTcwNjUyMDY5NzMyMDI3NzMyNz== Requesting UMT Server for Auth Data...SERVER_UNDER_MAINTENANCE Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 |
09-12-2020, 11:23 | #4 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1051138 Status: Offline Sonork: 123456 Thanks Meter: 382 | proof Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [storsec.mbn] -> [storsec] ...Done Writing [storsec.mbn] -> [storsecbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [pmic.elf] -> [pmic] ...Done Writing [pmic.elf] -> [pmicbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecapp] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecappbak] ...Done Writing [keymaster64.mbn] -> [keymaster] ...Done Writing [keymaster64.mbn] -> [keymasterbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [splash.img] -> [splash] ...Done Writing [persist.img] -> [persist] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img ] -> [cache]...Done Writing [system.img ] -> [system]...Done Writing [vendor.img ] -> [vendor]...Done Writing [cust.img ] -> [cust]...Done Writing [userdata.img ] -> [userdata]...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 6.0 |
09-12-2020, 11:23 | #5 (permalink) |
Member: 1051138 Status: Offline Sonork: 123456 Thanks Meter: 382 | Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro [tulip] Brand : xiaomi Prod.Name : tulip Software : PKQ1.180904.001, V11.0.5.0.PEKMIXM [Sat Aug 15 00:05:35 WIB 2020] Android Ver. : 9 Patch Level : 2020-07-05 Formatting userdata [SafeMode]...Done Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 6.0 |
The Following User Says Thank You to akeel2000 For This Useful Post: |
09-12-2020, 14:47 | #6 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | Operation : Xiaomi Boot Patch Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...Not Found! DebugData : BAAAABAAAAANAAAAAQAAAA== Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...Not Found! DebugData : BAAAABAAAAANAAAAAQAAAA== Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...OK Blob : NTI2NTYzNkY2NzZFNjk3QTY1NjQyMDQxNzQ3NDcyNjk2Mjc1Nz Q2NTIwNEU3NTZENjI2NTcyMjAzNTM2MjAyODI3NTQ2MTcyNjc2 NTc0NEU2MTZENjUyNzI5MjA3NzY5NzQ2ODIwNzY2MTZDNzU2NT IwMjc3MjY1NzEyNzIwNzQ3OTcwNjUyMDY5NzMyMDI3NzMyNz== Requesting UMT Server for Auth Data...SERVER_UNDER_MAINTENANCE Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 Device : Xiaomi Redmi Note 6 Pro Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...Not Found! DebugData : BAAAABAAAAANAAAAAQAAAA== Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 |
09-12-2020, 14:52 | #7 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | what am I doing wrong. redmi note 6 pro. mui9. I can not even unlock the bootloader, it goes into maintenance what day is it functional I have to get up early even so spending more than $ 10, 10 umt credits, |
09-14-2020, 13:52 | #8 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...Not Found! DebugData : BAAAABAAAAANAAAAAQAAAA== Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 |
09-14-2020, 13:56 | #9 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...Not Found! DebugData : BAAAABAAAAANAAAAAQAAAA== Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 Operation : Xiaomi Boot Patch Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZp Y2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj 0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVz cG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...OK Blob : NTI2NTYzNkY2NzZFNjk3QTY1NjQyMDQxNzQ3NDcyNjk2Mjc1Nz Q2NTIwNEU3NTZENjI2NTcyMjAzNTM2MjAyODI3NTQ2MTcyNjc2 NTc0NEU2MTZENjUyNzI5MjA3NzY5NzQ2ODIwNzY2MTZDNzU2NT IwMjc3MjY1NzEyNzIwNzQ3OTcwNjUyMDY5NzMyMDI3NzMyNz== Requesting UMT Server for Auth Data...SERVER_UNDER_MAINTENANCE Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.0 What day will I be able to get the account even so, having credits fails, I don't even sleep waiting for Tuesday to join with Venus to see if the server is active |
09-14-2020, 20:28 | #11 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | thanks big umt Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM22) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro [tulip] Brand : xiaomi Prod.Name : tulip Software : OPM1.171019.011, V9.6.8.0.OEKMIFD [Wed Sep 5 11:06:54 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-08-01 Reading Data... Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished. QcFire Ver. 6.0 |
The Following User Says Thank You to kervicell For This Useful Post: |
09-15-2020, 03:06 | #13 (permalink) |
Member: 1820429 Status: Offline Thanks Meter: 57 | make a format Then I wanted to deactivate my account, I got an error, wait a few hours, connect directly to reset my and it came out luckily |
