Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 09-15-2018, 10:37   #1 (permalink)
Member: 2395991
Thanks Meter: 41
Redmi Note 5 Pro Frp QC Fire 2.6
Here is the Loader
https://mega.nz/#!xZsUCI4Q!0FHcrv8fJ...kQw2OKEzQJmzZw
The Following 2 Users Say Thank You to registerrishi For This Useful Post:
Old 09-15-2018, 16:04   #2 (permalink)
Member: 2379235
Thanks Meter: 38
why misleading ppl with wrong title? its note 5 not note5 pro next time put correct title
Old 09-15-2018, 16:09   #3 (permalink)
Member: 1453066
Thanks Meter: 75
yes not 5 no Redmi Note 5 Pro
Old 09-15-2018, 16:25   #4 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 581
This is Note 5 Pro Only,,,
Just now tested this loader working 100%
But In Logs it is showing as Note 5...
Old 09-16-2018, 06:27   #5 (permalink)
Member: 2395991
Thanks Meter: 41
Bro it's note 5 pro tested
Old 09-16-2018, 12:53   #6 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
Operation : Reset Mi Account
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM351)
Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1C00C00 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Initializing Protocol...OK
Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done
Executing Loader...OK
Detecting Chip Type...Failed
Please use correct loader and check USB port / cable.
Operation Failed.
Failed always, try every loader but not success
Old 09-17-2018, 06:17   #7 (permalink)
Member: 2395991
Thanks Meter: 41
Originally Posted by somratjisan View Post
Operation: Reset Mi Account
Found Port: Qualcomm HS-USB QDLoader 9008 (COM351)
Driver Info: HS Corporation, ghsser.sys, 10.2104.1.2
Hardware ID: E1C00C00 [8996] 00000000
OPK_DATA: F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Operation Failed.
Bro use Qc fire 2.6 instead of 2.7
Sent from my TA-1053 using Tapatalk
Old 09-17-2018, 06:35   #8 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
This is v2.6 log bro.
Old 09-17-2018, 06:51   #9 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
friend your above logs shows Redmi note 5 not note 5 pro
Old 09-17-2018, 09:58   #10 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
This is note 5 pro, bro.
Old 09-17-2018, 11:24   #11 (permalink)
Member: 2395991
Thanks Meter: 41
Yes this Note 5 Pro Tested by me 1000%
Old 09-17-2018, 12:17   #12 (permalink)
Registered User
Member: 652541
Thanks Meter: 47
Old 09-17-2018, 12:40   #13 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
My Model is M1803E7SG, Try every loader given by users, but not success.
Old 09-17-2018, 13:08   #14 (permalink)
Member: 2147680
Thanks Meter: 32
my redmi note 5 pro china version, not work with loader
Old 09-17-2018, 13:24   #15 (permalink)
Member: 2395991
Thanks Meter: 41
Try may this help you
https://mega.nz/#!hV8EGAbL!kfypPr4ba...LpUXt_Z2k5KCHQ
The Following User Says Thank You to registerrishi For This Useful Post:
Page generated in 0.22595 seconds with 8 queries
