03-16-2018, 12:13 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: mumbai Age: 31
Member: 1526620 Status: Offline Sonork: 100.1646327 Thanks Meter: 69 | Redmi note 5 pro [mei7s] mi account not supported HERE LOG :- Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM7) Driver Info : Qualcomm Incorporated, qcusbser.sys, 5.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [0] CPU not found in database. Operation Failed. Module Ver. 1.9 |
The Following User Says Thank You to saifuuu7 For This Useful Post: |
03-16-2018, 15:27 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Thanks for log. We will try to add supportfor it in next update. Br, Ultimate Multi Tool |
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
03-24-2018, 11:26 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: jharkhand jamshedpur INDIA Age: 38
Member: 226587 Status: Offline Sonork: 100.1603781 Thanks Meter: 352 | Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM139) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Pro [sdm660] Software : NGI77B, V9.2.5.0.NEIMIEK [Tue Mar 6 22:31:05 CST 2018] Android Ver. : 7.1.1 Patch Level : 2018-02-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. Operation Finished. Module Ver. 2.0 unlock done mi Account b.r yuvi |
The Following User Says Thank You to Yuvi For This Useful Post: |
03-31-2018, 18:16 | #6 (permalink) |
No Life Poster Join Date: Oct 2013
Member: 2050872 Status: Offline Thanks Meter: 658 | Hello please see is use Executing Loader in factory file u can download flash file & select loder & try to reset mi a/c & all add this in next update br. UMT TEAM |
The Following User Says Thank You to hari.manju For This Useful Post: |
04-01-2018, 18:52 | #8 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
prog_emmc_firehose | |
The Following User Says Thank You to Franky_36 For This Useful Post: |
04-06-2018, 09:05 | #9 (permalink) |
Freak Poster Join Date: May 2010 Location: INDIA
Member: 1302506 Status: Offline Sonork: india Thanks Meter: 14 | Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM30) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Pro [sdm660] Software : NGI77B, V9.2.5.0.NEIMIEK [Tue Mar 6 22:31:05 CST 2018] Android Ver. : 7.1.1 Patch Level : 2018-02-01 Reading Data... Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished |
The Following User Says Thank You to dewoo For This Useful Post: |
04-09-2018, 19:34 | #11 (permalink) | ||||
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Read following post: Quote: What more detail you want? What not work? You should use your brain first, and also read these posts properly: Quote:
04-10-2018, 05:21 | #12 (permalink) |
Freak Poster Join Date: Feb 2010 Location: jattari
Member: 1239360 Status: Offline Thanks Meter: 95 | Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5 Pro [sdm660] Software : NGI77B, V9.2.6.0.NEIMIEK [Thu Mar 15 21:57:01 CST 2018] Android Ver. : 7.1.1 Patch Level : 2018-02-01 Reading Data... Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished. Module Ver. 2.0 |
04-12-2018, 08:57 | #14 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: SARDHANA MEERUT
Member: 1909641 Status: Offline Thanks Meter: 20 | Quote:
Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM29) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr_xiaomi.elf]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.0 | |
04-12-2018, 09:06 | #15 (permalink) |
Member: 1909641 Status: Offline Thanks Meter: 20 | Operation : Disable Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM29) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [E1C00C00] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Write Error! Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.0 Bro post full method ,i cant complete it |
The Following User Says Thank You to kanoniwal For This Useful Post: |
