09-15-2018, 16:16 | #1 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Redmi Note 5 Pro Wifi Problem After Remove MI Account Solved By UMT Port : Qualcomm HS-USB QDLoader 9008 (COM13) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Parsing Partition Entries...Done Writing [persist.img] -> [persist] ...Done Operation Finished. Module Ver. 2.6 Rebooting Device...Done |
09-16-2018, 08:15 | #2 (permalink) | |
Freak Poster Join Date: Sep 2015 Location: Lombok
Member: 2465890 Status: Offline Thanks Meter: 176 | You use mi auth account? Quote:
The Following User Says Thank You to AWEXSS For This Useful Post: |
09-16-2018, 11:44 | #3 (permalink) |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | No Need auth and bla bla bla with only loader which has been posted yesterday by many of the users... |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
09-16-2018, 12:47 | #4 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: In My Shop, Bangladesh
Member: 733449 Status: Offline Sonork: 100.334100 Thanks Meter: 292 | Quote:
Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM351) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...Failed Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.6 | |
09-16-2018, 19:02 | #5 (permalink) | |
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Quote:
What is ur model no???? | |
09-17-2018, 11:04 | #10 (permalink) |
No Life Poster Join Date: Sep 2017 Location: INDONESIA
Member: 2755295 Status: Offline Thanks Meter: 198 | https://mega.nz/#!xZsUCI4Q!0FHcrv8fJ...kQw2OKEzQJmzZw PLEASE TRY LOADER.TRY UMT V2.6 |
09-17-2018, 11:22 | #11 (permalink) | |
Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM351) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...Failed Please use correct loader and check USB port / cable. Operation Failed. Module Ver. 2.6 Try every loader given by users, but not success. | |
09-17-2018, 11:55 | #13 (permalink) |
Junior Member Join Date: Oct 2016 Location: Bangladesh
Member: 2635905 Status: Offline Thanks Meter: 2 | help me plz. i have oppo f5 youth cph1725. after flash all ok but camera not working and about phone show oppo f5 cph1723 but my phone cph1725. i am flash all cph1725 version firmware but no luck. plz help me any big brother. |
03-01-2019, 16:02 | #15 (permalink) | |
Product Supporter Join Date: Jun 2009 Location: eMMC & UFS
Member: 1045758 Status: Offline Sonork: 100.1613661(Offline) Thanks Meter: 4,307 | Quote:
Check with this file .. Redmi Note 5 Pro Mi Account FRP Redmi Note 5 Mi Account FRP Wbr, AniAXN | |
The Following 2 Users Say Thank You to AniAxn For This Useful Post: |
