02-28-2021, 12:49 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Please download new setup again from Support / Mirrors. Then first Disable Auth, and then select Model and click on Mi Account Reset. Br, UMT |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
02-28-2021, 14:56 | #3 (permalink) |
Freak Poster Join Date: Oct 2012 Location: transilvania
Member: 1820429 Status: Offline Thanks Meter: 57 | Operation: Disable Auth Waiting for device in BROM mode... Port: COM36 Port Name: MediaTek USB Port (COM36) Path: \\?\usb#vid_0e8d&pid_0003#6&36559b33&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0813, [MT6785] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success [UltimateMTK Ver. 3.8.1] Brand : Xiaomi Model : Note 8 Pro Operation : Reset Mi Account Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM36) Connect BROM failed: STATUS_BROM_CMD_STARTCMD_FAIL(-1073348607) Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8.1] |
The Following 2 Users Say Thank You to kervicell For This Useful Post: |
02-28-2021, 15:46 | #4 (permalink) | |
Freak Poster Join Date: Oct 2013 Location: tehran Age: 37
Member: 2048880 Status: Offline Thanks Meter: 63 | Quote:
Brand : Xiaomi Model : Note 8 Pro Operation : Reset Mi Account Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM158) Connect BROM failed: STATUS_SEC_AUTH_FILE_NEEDED(-1073545198) Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8.1] | |
02-28-2021, 16:07 | #5 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Please don't disconnect phone after disable auth. It should be connected as it is and then you should select model and reset mi account. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
02-28-2021, 16:23 | #6 (permalink) | |
Waiting for device in BROM mode... Port: COM158 Port Name: MediaTek USB Port_V1632 (COM158) Path: \\?\usb#vid_0e8d&pid_0003#7&35ebe39&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0813, [MT6785] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success [UltimateMTK Ver. 3.8.1] Brand : Xiaomi Model : Note 8 Pro Operation : Reset Mi Account Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM158) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Failed to Connect DA: STATUS_STORAGE_MISMATCH(-1073545210) Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 3.8.1] | |
The Following User Says Thank You to rezakeshavarza For This Useful Post: |
02-28-2021, 16:35 | #7 (permalink) | |
Freak Poster Join Date: Feb 2020 Location: Nigeria
Member: 2947987 Status: Offline Sonork: Null Thanks Meter: 72 | Quote:
Sent from my CPH1727 using Tapatalk | |
02-28-2021, 16:55 | #8 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Seems SEC AUTH NEEDED is resolved as you followed correct process. Please contact me in Private for beta test of UFS memory. Br, UMT | |
The Following 3 Users Say Thank You to U.M.T For This Useful Post: |
