09-02-2019, 15:28 | #1 (permalink) |
Freak Poster Join Date: Oct 2013 Location: Bangladesh
Member: 2049143 Status: Offline Sonork: not use Thanks Meter: 270 | redmi note5 pro unlock failed Searching for Device in FastBoot Mode...OK Reading Information...OK FastBoot Ver. : GetVar Variable Not found Product : whyred Bootloader : Locked Unlocking Bootloader...Failed QcFire Ver. 4.7 Operation : Xiaomi Boot Patch Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM27) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAFkBAABQ495e0_6dMze6v_R992sjgzYO4w Getting Auth Data...Connecttion to Auth App Failed! Run Auth App if not running, or restart Auth App! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.7 |
09-03-2019, 07:57 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Remove battery flex, hold Power button for 5 seconds. Now Short EDL TP and connect USB, once phone in EDL, connect Battery Flex. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
