09-19-2019, 09:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Dhaka mirpur-1 Age: 38
Member: 577653 Status: Offline Thanks Meter: 235 | Redmi note7 pro (violet) mi account remove failed Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM58) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1500900 [SM6150] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sm6150_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAGMBAAA_bG7TeQKdkSET5IRnTzAVsAK81A Getting Auth Data...Connecttion to Auth App Failed! Run Auth App if not running, or restart Auth App! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.7 Operation : Disable Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM58) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1500900 [SM6150] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6150]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAGMBAAA_bG7ThVApuZ8wf-aP6YbQuV6zKA Getting Auth Data...Connecttion to Auth App Failed! Run Auth App if not running, or restart Auth App! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.7 |
