03-15-2018, 16:18 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Greece Age: 38
Member: 173946 Status: Offline Sonork: 100.1585498 Thanks Meter: 42 | Remdi 4A can not repair imei Baud Rate : 921600 Device : Qualcomm Android Operation : Write IMEI [EFS Method] Opening Port... OK Reading Phone Information... Failed Port Closed. Operation Failed. Elapsed Time: 00:17 [Module Ver. 4.8] Log Saved to Logs\180315_171556.log How to solve the problem, where is problem my be bugs need help from supporter. |
03-15-2018, 18:49 | #3 (permalink) |
Member: 173946 Status: Offline Sonork: 100.1585498 Thanks Meter: 42 | Port : ADB Interface Baud Rate : Not Applicable Device : Qualcomm Android Operation : Enable Diag Searching for Device... Found Model : Redmi 4X Version : 7.1.2 Hardware : qcom Baseband : MPSS.TA.2.3.c1-00395-8953_GEN_PACK-1.110942.1.118028.1_V025 SIM Card : ABSENT,ABSENT CPU : arm64-v8a Type : Unknown MEID(1) : Null/Empty Checking Root Access... OK Root : Not Rooted Please root phone first. Operation Finished. Elapsed Time: 00:05 [Module Ver. 4.8] Log Saved to Logs\180315_194727.log without root I can not access Daig Port So if have any way any method to get root Please tell me. even can not access diagport with this code *#*#717717#*#* (For Diag Port Enable) Last edited by ub mobiles; 03-15-2018 at 18:55. |
03-15-2018, 19:28 | #4 (permalink) |
Member: 173946 Status: Offline Sonork: 100.1585498 Thanks Meter: 42 | Port : COM1387 : Qualcomm HS-USB Diagnostics 9091 (COM1387) Baud Rate : 921600 Device : Qualcomm Android Operation : Write IMEI [UMT Method [1]] Opening Port... OK Reading Phone Information... OK Compile : Dec 26 2017 16:57:26 Release : Apr 10 2017 09:00:00 Hw Ver. : 8940.gen Build : MPSS.TA.2.3.c1-00395-8953_GEN_PACK-1.122267.1.126477.1_V028 IMEI [1] : 867798030321567 IMEI [2] : 867798030321575 Method : UMT Method [1] Preparing Data... Done Writing IMEI 1 [354900069753955]... Done Writing IMEI 2 [356598596899966]... Done Rebooting Phone... Done Please reboot maunally if does not reboot automatically. Operation Finished. Elapsed Time: 00:06 [Module Ver. 4.8] Log Saved to Logs\180315_202520.log Finally I repaired IMEI of redmi 4X via software but not changed from Phone what should do now? |
03-16-2018, 06:16 | #5 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Try Method [2], if it also does not work, then you should try downgrade first. If that also does not work, make QCN Backup, then Reset Partial EFS using QcFire, then write back QCN and IMEI and it should be done. Br, Ultimate Multi Tool |
