03-22-2017, 13:26 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Rajasthan INDIA
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | Removing FRP Lock.. Failed! Protected Device But REAL Device Not Protected Solve BUG UMT LOG: [COLOR=Cyan][COLOR=White][SIZE=3][B]Now Showing In UMT [COLOR=Cyan][COLOR=White][SIZE=3][B][COLOR=Cyan][B]:Protected Device But Real Device Not Protected. Thanks & Regards By: Gopal Parmar Last edited by U.M.T; 03-23-2017 at 09:42. Reason: change real in capital |
The Following User Says Thank You to Yashbanswara For This Useful Post: |
03-23-2017, 06:52 | #3 (permalink) |
Member: 1147254 Status: Offline Sonork: 100.1620677 Thanks Meter: 639 | I Know Fastboot Mode & Flash Mode Not Same BUT Can You Tell In UMT Showing Protected Device But in xx Not Showing Protected Device & Successfully Unlock FRP. Tell Reason? Thanks & Regards By: Gopal Parmar Last edited by U.M.T; 03-23-2017 at 09:42. |
03-23-2017, 09:47 | #4 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Just because you dont have enough knowledge that does not entitle you to toss tue term BUG. Do you know why you can reset frp or mi account with QcFire but same thing fail with Fastboot Mode? Because it is protected by bootloader in phone which is active in fastboot mode. This is called protected when trying with Fastboot mode. If you connect same phone in EDL mode, phone's bootloader is not active so you can reset Mi Account or FRP. It is just an example to make you learn instead of ranting with baseless logics. And don't write like "please don't delete my post", bcoz if your post is against our rules we wil simply delete it. Comparing with any tool, either in good or bad way, is against our rules. Hope you understood, if not, must read it again. Br, Ultimate Multi Tool |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
03-24-2017, 08:48 | #5 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Mtk cpu frp need by mtk usb port Ok sir, all cpu frp done but mtk cpu problem cant remove mtk cpu frp you add mtk cpu frp by (mtk usb port) |
