02-29-2024, 21:15 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: ttfoutdd
Member: 1161437 Status: Offline Sonork: nokia Thanks Meter: 50 | Samsung A426U Soft Brick After KG Bypass Phone firmware version A426USQU3CVC3 Please Help me |
02-29-2024, 21:57 | #2 (permalink) |
Member: 1161437 Status: Offline Sonork: nokia Thanks Meter: 50 | Device : Samsung Galaxy A42 5G (SM-A426U) BIT7 Operation : Samsung KG Bypass Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM8) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1301600 [SM7225] 00002000 OPK_DATA : CC251C7CA9DB280473AF0A7FFAE89A9CD60D06266837AC1061 9E309C69008DF9 Initializing Protocol...OK Using Pre-Defined Loader [SM-A426U BIT7.ufl] Preparing Loader...Done Sending Loader [SM-A426U BIT7]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SM7225, UFS, 128 GB LU Count : 6 [0x01DB0800] [0x00000800] [0x00000800] [0x00000400] [0x00018000] [0x00000C00] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Software : SP1A.210812.016.A426USQU3CVC3, A426USQU3CVC3 [Fri Mar 11 21:00:04 KST 2022] Android Ver. : 12 Patch Level : 2022-03-01 Bypassig KG Lock... Done Done Done Done Once phone reboot in Odin Mode, full flash your device. Operation Finished. QcFire Ver. 9.3 |
03-02-2024, 21:12 | #4 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,461 | It is already mentioned that you need to full flash phone after this operation. Also keep in mind that this method only allows you to full flash phone if flashing is blocked due to KG. Downlaod 4 File firmware and flash in via Samsung Module or Odin. Br, UMT |
