01-15-2017, 07:22 | #1 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Mahoba
Member: 1810159 Status: Offline Thanks Meter: 256 | Samsung G610F frp remove by UMT [SUCCESS REPORT] Operation: Apply FRP Patch Port: COM11 : SAMSUNG Mobile USB Modem #2 Checking for Device... Found [Download Mode] Reading Data from Phone... Done Chipset: LSI7870 [HiSpeed] Applying Patch Data... . . . . Done Closing Session... Done ---------------- IMPORTANT ---------------- Wait for phone to reboot and turn on fully or TURN ON manually. Please install driver once SAMSUNG_Android Device is detected. Once ADB Drivers are installed, use Reset FRP button. Elapsed Time: 00:22 [Ultimate Samsung Flasher v0.8] ================================================== === Device: SM-G610F Operation: Reset FRP Searching for Device... Found Model: SM-G610F Baseband: Bootloader: G610FDDU1API2 PDA: G610FDDU1APL9 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:09 [Ultimate Samsung Flasher v0.8] |
The Following User Says Thank You to sktamrkar For This Useful Post: |
07-19-2017, 22:27 | #4 (permalink) | ||
Freak Poster Join Date: Dec 2010
Member: 1478562 Status: Offline Thanks Meter: 54 | Quote:
Flash latest firmware but nothing happened..... Problem not solved... | ||
07-20-2017, 05:22 | #6 (permalink) | |
But even downgrade the firmware (April 2016) security patch .. No use same problem.. Due to TAT time return handset to the customer | |
08-21-2017, 10:11 | #8 (permalink) |
Member: 1478562 Status: Offline Thanks Meter: 54 | Finaly i got success with help of this video.... thanks to helps.... new security 2017 samsung g610f j7 prime frp lock solution 100% easy video... https://*********/-69SZ2UFcsI success video |
