02-28-2024, 07:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: india
Member: 1140831 Status: Offline Sonork: no Thanks Meter: 232 | samsung m02s after kg lock remove not full flash plz help Model : Samsung Universal Operation : Flash Searching for Phone...Found Port: : COM11 : SAMSUNG Mobile USB Modem #7 Checking for Device...Found [Download Mode] Reading Data from Phone...Done Chipset : SDM710 [HiSpeed] Sending Partition [ABOOT]...Done Sending Partition [SBL1]...Done Sending Partition [RPM]...Done Sending Partition [TZ]...Done Sending Partition [DEVCFG]...Done Sending Partition [CMNLIB]...Done Sending Partition [CMNLIB64]...Done Sending Partition [KEYMASTER]...Done Sending Partition [APDP]...Done Sending Partition [MSADP]...Done Sending Partition [APNHLOS]...Done Sending Partition [SEC]...Done Sending Partition [DSP]...Done Sending Partition [BKSECAPP]...Done Sending Partition [VK]...Done Sending Partition [BOOT]...Done Sending Partition [DTBO]...Done Sending Partition [RECOVERY]...Done Sending Partition [SUPER]...Done Sending Partition [USERDATA]...Blocked! Operation Failed. Elapsed Time 04:14 [UltimateSams v0.7] |
02-28-2024, 12:06 | #2 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | Quote:
b.r. | |
The Following User Says Thank You to bk.gsm For This Useful Post: |
03-02-2024, 21:19 | #4 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,464 | Try to flash again. If an error appears on phone screen or in software, simply unselect partition which are already flashed and try to flash again remaining parts. If this error is coming randomly, try switching to different port or cable. Br, UMT |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
03-03-2024, 11:19 | #5 (permalink) |
Freak Poster Join Date: Mar 2013 Location: india madhy pradesh indore
Member: 1892909 Status: Offline Sonork: 100.1647570 Thanks Meter: 39 | after that all you have done as all supporters say , just check ones charging jack because several time cc is drysold or any minor damage cc and usb cable cant communicate properly is your problem solve please post here with logs or screenshorts br. |
