12-15-2018, 10:44 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | Smartisun nut pro 2 User lock reset problem Device : Smartisan Nut Pro 2 Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 22001100 OPK_DATA : 2EC99C0A1B86E71B81744418E91A9BF774DD51EE2CDFC409FE B24AF51A5B13E8 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8976_011]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.4 Format FS also failed Device : Smartisan Nut Pro 2 Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 22001100 OPK_DATA : 2EC99C0A1B86E71B81744418E91A9BF774DD51EE2CDFC409FE B24AF51A5B13E8 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8976_011]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.4 How to solve this problem team make a quick solution if i did do something wrong ?? |
12-15-2018, 12:53 | #3 (permalink) |
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | Device : Smartisan Nut Pro 2 Operation : Read Information Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8976] 22001100 OPK_DATA : 2EC99C0A1B86E71B81744418E91A9BF774DD51EE2CDFC409FE B24AF51A5B13E8 Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8976_011]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.5 still same ??? |
12-16-2018, 10:07 | #5 (permalink) |
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | Will you please tell me what i need to do Hello_sir_what_now_no_soltion_with_umt_or_it_just_ fake_solution Last edited by U.M.T; 12-17-2018 at 16:03. |
12-17-2018, 16:04 | #6 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | I was updating loader for you. But as you have already called fake solution, so now it does not make sense to provide updated loader. So now for you, not supported. Br, UMT |
12-18-2018, 08:08 | #7 (permalink) | |
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | Quote:
and this is now the way to treat your customers Its up on you. your call I can't do that such of thing with my customer i m recently buy umt tool to see lots of success report but sorry to say very bad reply from you sir by they keep it up Thanks for reply | |
01-18-2019, 08:30 | #11 (permalink) | |
and phone is in listed that's why i say Forget it In short i just ask for solution with say yes or no word only | |
