07-09-2017, 12:21 | #1 (permalink) |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | [TUTORIAL] Huawei e5573cs-609 Unlock ★★★★★ FOLOW THIS GUIDE FOR UNLOCK A MODEM 1-UNSCREW A MODEM 2-INSTALL HUAWEI DRIVERS IN PC 3-INSERT BATTERY IN A ROUTER 4-SHORT A TESTPOINT OF MODEM(DONT SOLDER A BOOTPOINT TO GND) 5-CONNECT ROUTER USB TO PC IN A DEVICE MANGER IN WINDOWS PC UI COM PORT DETECT(NOW REMOVE TWEEZER FROM BOOT POINTS) OPEN UMT GSM SOFTWARE (SELECT HUAWEI HISILICON) 6-SCAN THE PORT 7-IN A DROP DOWN LIST SELECT-HUAWEI MOBILE CONNECT-3G PC UI PORT 8-AFTER THIS SELCT OPTION HUAWEI BOOT REPAIR-SELECT E5573CS-609 9-CLICK REPAIR 10-AFTER BOOT WRITE DONE AGAIN SCAN THE PORTS 11-AFTER THIS SELECT IN MODEL LIST SELECT E5573 12-TICK EMERGENCY MODE 13-SELECT FIRMWARE- E5573cs_UPDATE_21.318.99.03.00.BIN 14-WRITE A FIRMWARE 15-AFTER SEUCESSFULLY FIRMWARE WRITE DONE AGAIN SCAN THE PORTS AND SELCT PC UI COM PORT 16-AND CLICK THE BUTTON UNLOCK 17-AFTER UNLOCK UNTICK THE EMERGENCY OPTION 19 WRITE 2ND FIRMWARE -SELECT FIRMWARE E5573cs_UPDATE_21.318.03.00.00.BIN 20-WRITE THE FIRMWARE AFTER SUCESSFULLY FLASHING A FIRMWARE MODEM WILL REBOOT AND RESTORE TO WORKING CONDITION BR-BALWINDER27 UMT-TEAM |
The Following 28 Users Say Thank You to balwinder27 For This Useful Post: |
