03-16-2017, 08:31 | #31 (permalink) |
No Life Poster Join Date: Apr 2007 Location: searching .... Age: 16
Member: 484060 Status: Offline Sonork: 100.1596821 Thanks Meter: 406 | Oppo A57 (CPH1701) 8940 Cpu All Test Done By Qcfire Code: Operation : Format FS Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM68) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... Ignored Init Handshake Sequence... OK Hardware ID : E1B00600 [8940] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8940.ufl]... Done Executing Loader... OK Hardware : 8937, eMMC, 32 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... Failed Preparing Data... Done Formatting Userdata... Done Operation Finished. Code: Operation : Reset FRP Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1B00600 [8940] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8940.ufl]... Done Executing Loader... OK Hardware : 8937, eMMC, 32 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... Failed Resetting FRP Lock... . . Done Operation Finished. Code: Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM12) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1B00600 [8940] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8940.ufl]... Done Executing Loader... OK Hardware : 8937, eMMC, 32 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... Failed Reading [modem]... Done Reading [sbl1]... Done Reading [sbl1bak]... Done Reading [rpm]... Done Reading [rpmbak]... Done Reading [tz]... Done Reading [tzbak]... Done Reading [devcfg]... Done Reading [devcfgbak]... Done Reading [dsp]... Done Reading [oppodycnvbk]... Done Reading [oppostanvbk]... Done Reading [LOGO]... Done Reading [sec]... Done Reading [splash]... Done Reading [aboot]... Done Reading [abootbak]... Done Reading [boot]... Done Reading [recovery]... Done Reading [cache]... Done Reading [system]... Done Reading [persist]... Done Reading [misc]... Done Reading [mdtp]... Done Reading [cmnlib]... Done Reading [cmnlibbak]... Done Reading [cmnlib64]... Done Reading [cmnlib64bak]... Done Reading [keymaster]... Done Reading [keymasterbak]... Done Reading [DRIVER]... Done Reading [userdata]... Done Reading [PrimaryGPT]... Done Reading [BackupGPT]... Done Operation Finished. $ktelecom |
The Following 2 Users Say Thank You to $ktelecom For This Useful Post: |
03-16-2017, 11:35 | #32 (permalink) |
Major Poster Join Date: Apr 2009 Location: solo the spirit of java
Member: 1005417 Status: Offline Sonork: 100.1603146 Thanks Meter: 8 | Hello UMT Team Please Add FRP For OnePlus A3003 MSM8996 Operation : Reset FRP Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.0 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1709400 [8996] [B93D702A] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8996.ufl]... Error Please use correct loader and check USB port / cable. Operation Failed. NOT Support xxx update 0.4 |
03-16-2017, 13:06 | #35 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Xiaomi Redmi Note 4 Reading Pattern Data... Failed Operation : Read Pattern Lock Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM28) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.0 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1600400 [8953] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8953.ufl]... Done Executing Loader... OK Hardware : 8953, eMMC, 32 GB Warning! High Speed Driver not installed. Please install driver from QcFire\Drivers folder. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : Xiaomi Redmi Note 4 [msm8953] Software : MMB29M, V8.1.15.0.MCFMIDI [Thu Feb 16 19:24:53 WIB 2017] Android Ver. : 6.0.1 Operation Failed. |
03-16-2017, 13:25 | #36 (permalink) | |
Freak Poster Join Date: Nov 2016
Member: 2645658 Status: Offline Thanks Meter: 63 | Quote:
Added Pattern Lock Read - You can now read pattern lock, shall work on devices with Android < 6.x - Some phones have encrypted or incompatible userdata format, so it may fail on such device. your device greater than 6.x so try to factory reset(read firmware before operation) the device.... | |
03-16-2017, 14:17 | #37 (permalink) |
Junior Member Join Date: Nov 2015 Location: Brasil
Member: 2485125 Status: Offline Thanks Meter: 4 | Help Moto Devices How did you recognize the device? I try and go in fastboot mode please help me |
The Following User Says Thank You to LUCASMIXBH For This Useful Post: |
03-16-2017, 14:31 | #38 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: India
Member: 666414 Status: Offline Thanks Meter: 38 | Quote:
03-16-2017, 17:24 | #39 (permalink) |
Freak Poster Join Date: Jul 2016 Location: JOMBANG, JATIM
Member: 2600625 Status: Offline Sonork: aly_alumni_ptc Thanks Meter: 58 | hi umt team many people as technician mobile cellular love your product i know u are not stop in here to give the best performance for ur tool.....i think very powerful ur product especially for frp samsung.....good update be the best tool in the world |
03-16-2017, 23:34 | #40 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Cuba Age: 36
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | Failed to read firmware on TCL OT-5056N secure boot Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Android HS-USB QDLoader 9008 (COM94) Driver Info : TCL, qcusbser.sys, 6.0.0.0 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [22004200] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Write Error! Please use correct loader and check USB port / cable. |
03-17-2017, 05:06 | #42 (permalink) | |
Freak Poster Join Date: Feb 2009 Location: heven
Member: 969337 Status: Offline Sonork: 100.1608846 Thanks Meter: 32 | Quote:
