03-31-2017, 18:21 | #62 (permalink) | |
No Life Poster Join Date: Apr 2010 Location: Paradise on Earth
Member: 1281866 Status: Offline Thanks Meter: 330 | Quote:
but if u read my previous post again you can now under stand what i was trying to say there was no option on umt (qcfire ) to put handset in edl mode now the new version supports from fast b..t to edl hope the question is now clear sorry for my bad english | |
04-03-2017, 04:21 | #66 (permalink) |
Insane Poster Join Date: Dec 2010
Member: 1464653 Status: Offline Thanks Meter: 12 | samsung j710f frp reset done Device: SM-J710F Operation: Reset FRP Searching for Device... Found Model: SM-J710F Baseband: J710FXXU1APH5 Bootloader: J710FXXU1APG1 PDA: J710FXXU1API2 Android Version: 6.0.1 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Tap Next > Next > Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:06 [Ultimate Samsung Flasher v1.0] |
04-03-2017, 04:24 | #67 (permalink) |
Member: 1464653 Status: Offline Thanks Meter: 12 | lyf ls 5016 8gb flesh done umt Operation : Flash Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM92) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Done Executing Loader... OK Hardware : 8909, eMMC, 8 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Writing NON-HLOS.bin ... Done Writing sbl1.mbn ... Done Writing sbl1.mbn ... Done Writing emmc_appsboot.mbn ... Done Writing emmc_appsboot.mbn ... Done Writing rpm.mbn ... Done Writing rpm.mbn ... Done Writing tz.mbn ... Done Writing tz.mbn ... Done [PROTECTIVE_FLASH] Skipping zero.bin [PROTECTIVE_FLASH] Skipping zero.bin Writing splash.img ... Done [PROTECTIVE_FLASH] Skipping fsg_rlc01a.img Writing sec.dat ... Done Writing boot.img ... Done Writing system_1.img ... Done Writing system_2.img ... Done Writing system_3.img ... Done Writing system_4.img ... Done Writing system_5.img ... Done Writing system_6.img ... Done Writing system_7.img ... Done Writing system_8.img ... Done Writing system_9.img ... Done Writing system_10.img ... Done Writing system_11.img ... Done Writing system_12.img ... Done Writing system_13.img ... Done Writing system_14.img ... Done Writing system_15.img ... Done Writing system_16.img ... Done Writing system_17.img ... Done Writing system_18.img ... Done Writing system_19.img ... Done Writing system_20.img ... Done Writing system_21.img ... Done Writing system_22.img ... Done Writing system_23.img ... Done Writing system_24.img ... Done Writing system_25.img ... Done Writing system_26.img ... Done Writing system_27.img ... Done Writing system_28.img ... Done Writing system_29.img ... Done Writing system_30.img ... Done Writing system_31.img ... Done Writing system_32.img ... Done Writing system_33.img ... Done Writing system_34.img ... Done Writing system_35.img ... Done Writing system_36.img ... Done Writing system_37.img ... Done Writing system_38.img ... Done Writing system_39.img ... Done Writing system_40.img ... Done Writing persist_1.img ... Done Writing cache_1.img ... Done Writing cache_2.img ... Done Writing cache_3.img ... Done Writing recovery.img ... Done Writing userdata_1.img ... Done Writing userdata_2.img ... Done Writing userdata_3.img ... Done Writing userdata_4.img ... Done Writing userdata_5.img ... Done Writing userdata_6.img ... Done Writing userdata_7.img ... Done Writing userdata_8.img ... Done Writing userdata_9.img ... Done Writing userdata_10.img ... Done Writing userdata_11.img ... Done Writing userdata_12.img ... Done Writing userdata_13.img ... Done Writing userdata_14.img ... Done Writing userdata_15.img ... Done Writing userdata_16.img ... Done Writing userdata_17.img ... Done Writing userdata_18.img ... Done Writing userdata_19.img ... Done Writing userdata_20.img ... Done Writing userdata_21.img ... Done Writing userdata_22.img ... Done Writing userdata_23.img ... Done Writing userdata_24.img ... Done Writing userdata_25.img ... Done Writing userdata_26.img ... Done Writing userdata_27.img ... Done Writing userdata_28.img ... Done Writing userdata_29.img ... Done Writing userdata_30.img ... Done Writing userdata_31.img ... Done Writing userdata_32.img ... Done Writing userdata_33.img ... Done Writing userdata_34.img ... Done Writing userdata_35.img ... Done Writing userdata_36.img ... Done Writing userdata_37.img ... Done Writing userdata_38.img ... Done Writing userdata_39.img ... Done Writing userdata_40.img ... Done Writing userdata_41.img ... Done Writing userdata_42.img ... Done Writing userdata_43.img ... Done Writing gpt_main0.bin ... Done Writing gpt_backup0.bin ... Done Applying Patches... . . . . . . . . . . . . . Done Resetting device... Done Operation Finished. |
04-03-2017, 04:27 | #68 (permalink) |
Member: 1464653 Status: Offline Thanks Meter: 12 | oppo a37 frp reset done one click by umt Operation : Reset FRP Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8916.ufl]... Done Executing Loader... OK Hardware : 8916, eMMC, 16 GB Payload Info : In: 262144 [4096], Out: 16384, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : OPPO A37f [msm8916] Software : A37fEX_11_170302, 1480422943 [Thu Mar 2 08:44:55 CST 2017] Android Ver. : 5.1.1 Resetting FRP Lock... . . Done Operation Finished. |
04-03-2017, 04:29 | #69 (permalink) |
Member: 1464653 Status: Offline Thanks Meter: 12 | vivo vivo Y21L Format done one click by umt Operation : Format FS Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM14) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1507000 [8916] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8916.ufl]... Done Executing Loader... OK Hardware : 8916, eMMC, 16 GB Payload Info : In: 262144 [4096], Out: 16384, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : vivo vivo Y21L [msm8916] Software : LMY47V release-keys, eng.compiler.20161219 [Mon Dec 19 20:48:33 CST 2016] Android Ver. : 5.1.1 Preparing Data... Done Formatting Userdata... Done Operation Finished. |
04-03-2017, 04:31 | #70 (permalink) |
Member: 1464653 Status: Offline Thanks Meter: 12 | LYF LS-4505 frp reset done one click by umt Operation : Reset FRP Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM92) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Done Executing Loader... OK Hardware : 8909, eMMC, 8 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : LYF LS-4505 [msm8909] Software : LS-4505-S22A_LYF_L12EN_202_160930, 24decd3 [Fri Sep 30 11:19:34 CST 2016] Android Ver. : 6.0.1 Resetting FRP Lock... . . Done Operation Finished. |
04-03-2017, 04:34 | #71 (permalink) |
Member: 1464653 Status: Offline Thanks Meter: 12 | redmi 3s prime pattern lock remove umt Searching for phone in sideload mode... Found Device Id : land_global Version : V8.1.1.0.MALMIDI Code Base : 6.0.1 Ext Info : GB, en, F Formatting Data... Done Operation Finished. |
The Following User Says Thank You to rammaurya For This Useful Post: |
04-03-2017, 04:41 | #72 (permalink) |
Member: 1464653 Status: Offline Thanks Meter: 12 | lyf ls 5016 deth recover done 100% tested by umt Operation : Flash Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM92) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Done Executing Loader... OK Hardware : 8909, eMMC, 16 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Writing NON-HLOS.bin ... Done Writing sbl1.mbn ... Done Writing sbl1.mbn ... Done Writing emmc_appsboot.mbn ... Done Writing emmc_appsboot.mbn ... Done Writing rpm.mbn ... Done Writing rpm.mbn ... Done Writing tz.mbn ... Done Writing tz.mbn ... Done [PROTECTIVE_FLASH] Skipping zero.bin [PROTECTIVE_FLASH] Skipping zero.bin Writing splash.img ... Done [PROTECTIVE_FLASH] Skipping fsg_rlc01a.img Writing sec.dat ... Done Writing boot.img ... Done Writing system_1.img ... Done Writing system_2.img ... Done Writing system_3.img ... Done Writing system_4.img ... Done Writing system_5.img ... Done Writing system_6.img ... Done Writing system_7.img ... Done Writing system_8.img ... Done Writing system_9.img ... Done Writing system_10.img ... Done Writing system_11.img ... Done Writing system_12.img ... Done Writing system_13.img ... Done Writing system_14.img ... Done Writing system_15.img ... Done Writing system_16.img ... Done Writing system_17.img ... Done Writing system_18.img ... Done Writing system_19.img ... Done Writing system_20.img ... Done Writing system_21.img ... Done Writing system_22.img ... Done Writing system_23.img ... Done Writing system_24.img ... Done Writing system_25.img ... Done Writing system_26.img ... Done Writing system_27.img ... Done Writing system_28.img ... Done Writing system_29.img ... Done Writing system_30.img ... Done Writing system_31.img ... Done Writing system_32.img ... Done Writing system_33.img ... Done Writing persist_1.img ... Done Writing cache_1.img ... Done Writing cache_2.img ... Done Writing cache_3.img ... Done Writing recovery.img ... Done Writing userdata_1.img ... Done Writing userdata_2.img ... Done Writing userdata_3.img ... Done Writing userdata_4.img ... Done Writing userdata_5.img ... Done Writing userdata_6.img ... Done Writing userdata_7.img ... Done Writing userdata_8.img ... Done Writing userdata_9.img ... Done Writing userdata_10.img ... Done Writing userdata_11.img ... Done Writing userdata_12.img ... Done Writing userdata_13.img ... Done Writing userdata_14.img ... Done Writing userdata_15.img ... Done Writing userdata_16.img ... Done Writing userdata_17.img ... Done Writing userdata_18.img ... Done Writing userdata_19.img ... Done Writing userdata_20.img ... Done Writing gpt_main0.bin ... Done Writing gpt_backup0.bin ... Done Applying Patches... . . . . . . . . . . . . . Done Resetting device... Done Operation Finished. |
04-03-2017, 04:45 | #73 (permalink) |
Member: 1464653 Status: Offline Thanks Meter: 12 | lyf ls 5016 frp reset done Operation : Reset FRP Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM92) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1009600 [8909] [00000000] Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8909.ufl]... Done Executing Loader... OK Hardware : 8909, eMMC, 16 GB Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table... OK Reading Device Information... OK Device : unknown LS-5016 [msm8909] Software : LS-5016-S17A_LYF_L11EN_202_160229, 90e09f8 [Tue Sep 13 20:22:22 CST 2016] Android Ver. : 5.1.1 Resetting FRP Lock... . . Done Operation Finished. |
