12-05-2017, 05:49 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: karor lal-esan pakistan
Member: 427028 Status: Offline Sonork: 100.1639042 Thanks Meter: 63 | huawei modem e5573cs-609 dead after unlock Port : COM79 : HUAWEI Mobile Connect - 3G PC UI Interface (COM79) Baud Rate : 921600 Device : Huawei E5573 Operation : Read Info Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E5573CS-609 Revision : 21.318.99.03.00 IMEI : 000000000000000 Build : May 13 2016, 11:47:37 Software : 21.318.99.03.00 Dashbaord : 00.00.00.000.00 Hardware : CL1E5573CSM Ver.B Flash Code : 64841660 Lock Status : Unknown (0 Attempts Left) Port Closed. Operation Finished. Elapsed Time: 00:02 [Module Ver. 4.4] Log Saved to Logs\171204_115307.log but when i flash it with fanil file its gone dead i try three time plz tell me what can i do after that info?? Port : COM79 : HUAWEI Mobile Connect - 3G PC UI Interface (COM79) Baud Rate : 921600 Device : Huawei E5573 Operation : Read Info Opening Port... OK Reading Information... OK Manufacturer : huawei Model : E5573CS-609 Revision : 21.318.99.03.00 IMEI : 000000000000000 Build : May 13 2016, 11:47:37 Software : 21.318.99.03.00 Dashbaord : WEBUI_17.100.11.00.03_MRE5 Hardware : CL1E5573CSM Ver.B Flash Code : 64841660 Lock Status : Unknown (0 Attempts Left) Port Closed. Operation Finished. Elapsed Time: 00:02 [Module Ver. 4.4] Log Saved to Logs\171205_095223.log after that there is no ip adress working on divces charging and signal light only green light Last edited by haydernaz; 12-05-2017 at 05:56. |
12-05-2017, 06:40 | #2 (permalink) | |
No Life Poster Join Date: Oct 2016 Location: Developer
Member: 2634133 Status: Offline Thanks Meter: 2,939 | Quote:
21.318.99.03.00 write 2nd firmware 21.318.03.00 (untick emergency mode) after flash done .your modem restore to working condition IF YOUR MODEM IS TELENOR EE5573CS-609 21.323.01.01.274 THEN 2ND FIRMWRAE NOT WORK AS I SEE YOU USED USBLOADER FOR NV KILL THEN YOUR MODEM IMEI KILL 000000000 br-balwinder27 umt-team | |
The Following 3 Users Say Thank You to balwinder27 For This Useful Post: |
12-07-2017, 05:58 | #3 (permalink) | |
Member: 427028 Status: Offline Sonork: 100.1639042 Thanks Meter: 63 | now what can i do Quote:
now what can i do | |
01-01-2018, 12:10 | #5 (permalink) | |
so we only supurt safe unlock devices only br-balwinder27 umt-team | |
The Following User Says Thank You to balwinder27 For This Useful Post: |
08-16-2019, 10:33 | #8 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1989522 Status: Offline Thanks Meter: 0 | slam to all sir i mara sath problam ya hoi k jub zong huawei e5573cs -322 ka firmware upload complete ho gia to usi wqt modem ki signal wali red ligh on ho gai. mana pc sa unplug kia dubara restart kia but woi red light boot mode ma on kia huawei mobile connect 3g PC UI interface driver not responding and no other usb device work that i conect after this please give me any idea how i reset my modem on defalt |
