12-09-2019, 04:42 | #1 (permalink) |
Freak Poster Join Date: Apr 2017 Location: Tajikistan
Member: 2704006 Status: Offline Thanks Meter: 181 | Unlock bootloader failed, but credit gone Code: Operation : Xiaomi Boot Patch Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00B00 [8953] 00007200 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD379930D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_027]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2MzA0MjQxNDE0MTcyNzU2QTc1Njg0NzZFNDEzOTZGNkQ0RDZENUY1NDQ2Njk2QzRFNkI1OTZGNjU0MTU0NjI3Nz== Requesting UMT Server for Auth Data...OK Credits Left: 9 Authenticating...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 32 GB LU Count : 1 [0x03A3E000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...Failed Processing Redmi_7.....Done Rebooting to Fastboot...Done Put phone in Fastboot mode if it is not in Fastboot Mode. Then try Unlock BL in Fastboot Mode. Operation Finished. QcFire Ver. 5.0 Code: Operation : Bootloader Unlock (Fastboot) Searching for Device in FastBoot Mode...OK Reading Information...OK FastBoot Ver. : 0.5 Product : onc Warranty : Yes Bootloader : Locked Unlocking Bootloader...Failed QcFire Ver. 5.0 What's wrong, maybe bug in software. |
12-09-2019, 09:00 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,556 | About refund related query, please check our terms and conditions here: http://forum.gsmhosting.com/vbb/f970...odels-2723320/ And yes, always search before post. Br, |
12-09-2019, 09:02 | #4 (permalink) | |
Member: 2704006 Status: Offline Thanks Meter: 181 | Quote:
12-09-2019, 09:04 | #5 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,556 | When we said bootloader unlock needs credit? Credit is used simply for auth, whether you use it for simple read info. First understand what is auth amd only then use Credit for it. We have already warned about it. |
12-09-2019, 09:10 | #6 (permalink) | |
Can I unlock bootloader without any problem? | |
12-09-2019, 09:13 | #7 (permalink) | |
But this problem show only in this phone. | |
