06-15-2018, 00:03 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Cali Colombia Age: 43
Member: 181405 Status: Offline Thanks Meter: 249 | VIVO x9 E failed to mount data on /dev/block/dm-0 E failed to mount /data on /dev/block/dm-0 (Invalid argument) I need unbrick my phone Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM109) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 8AFE481418821A58BBBAC5EBB9B8452C407AA19E772EB17004 B04A591507E40C Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8953_004.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [adspso.bin] -> [dsp] ...Done Writing [sec.dat] -> [sec] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img] -> [cache] ...Done Writing [oem.img] -> [oem] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [survival.img] -> [survival] ...Done Writing [dp_AP_signed.mbn] -> [apdp] ...Done Writing [dp_MSA_signed.mbn] -> [msadp] ...Done Writing [apps.img] -> [apps] ...Done Writing [userdata.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Writing [system_1.img] -> [system] ...Done Writing [system_2.img] -> [system] ...Done Writing [system_3.img] -> [system] ...Done Writing [system_4.img] -> [system] ...Done Writing [system_5.img] -> [system] ...Done Writing [system_6.img] -> [system] ...Done Writing [system_7.img] -> [system] ...Done Writing [system_8.img] -> [system] ...Done Writing [system_9.img] -> [system] ...Done Writing [system_10.img] -> [system] ...Done Writing [system_11.img] -> [system] ...Done Writing [system_12.img] -> [system] ...Done Writing [system_13.img] -> [system] ...Done Writing [system_14.img] -> [system] ...Done Writing [system_15.img] -> [system] ...Done Writing [system_16.img] -> [system] ...Done Writing [system_17.img] -> [system] ...Done Writing [system_18.img] -> [system] ...Done Writing [system_19.img] -> [system] ...Done Writing [system_20.img] -> [system] ...Done Writing [system_21.img] -> [system] ...Done Writing [system_22.img] -> [system] ...Done Writing [system_23.img] -> [system] ...Done Writing [system_24.img] -> [system] ...Done Writing [system_25.img] -> [system] ...Done Writing [system_26.img] -> [system] ...Done Writing [system_27.img] -> [system] ...Done Writing [system_28.img] -> [system] ...Done Writing [system_29.img] -> [system] ...Done Writing [system_30.img] -> [system] ...Done Writing [system_31.img] -> [system] ...Done Writing [system_32.img] -> [system] ...Done Writing [system_33.img] -> [system] ...Done Writing [system_34.img] -> [system] ...Done Writing [system_35.img] -> [system] ...Done Writing [system_36.img] -> [system] ...Done Writing [system_37.img] -> [system] ...Done Writing [system_38.img] -> [system] ...Done Writing [system_39.img] -> [system] ...Done Applying Patches................Done Resetting device...Failed Remove cable, reconnect battery / hold Power Button ~15 seconds. Operation Finished. Module Ver. 2.4 steel bricked Last edited by hector bermudez; 06-15-2018 at 00:09. |
06-15-2018, 04:54 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You should enter recovery and try to wipe phone, and again enter recovery to check if that error message has gone. Also try to flash with 100% correct firmware (as Vivo has worst kind of model identification system) and latest update. Another option is to find OTA package and use memory card to update via recovery. In worst case, it may be issue with eMMC. Br, UMT |
06-15-2018, 17:01 | #3 (permalink) | |
Member: 181405 Status: Offline Thanks Meter: 249 | Quote:
I can not find ota firmware In advance thanks for the help | |
06-15-2018, 19:27 | #4 (permalink) | |
No Life Poster Join Date: May 2015 Location: mumbai Age: 27
Member: 2401939 Status: Offline Thanks Meter: 682 | Quote:
