05-14-2017, 07:32 | #1 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Mahoba
Member: 1810159 Status: Offline Thanks Meter: 256 | Vivo y55 qualcomm loader Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM93) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1F00400 [8937] 00000000 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8937.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM93) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1F00400 [8937] 00000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8937_1.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM93) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1F00400 [8937] 00000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8937_2.ufl]... Write Error! Please use correct loader and check USB port / cable. Operation : Read Firmware Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM93) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1F00400 [8937] 00000000 Initializing Protocol... OK Preparing Firehose Loader... Done Sending Loader [8937_3.ufl]... Write Error! Please use correct loader and check USB port / cable. Share the loader thnx Sandeep Kumar |
The Following User Says Thank You to sktamrkar For This Useful Post: |
05-14-2017, 09:55 | #2 (permalink) | |
Freak Poster Join Date: Jun 2009 Location: Austria
Member: 1050590 Status: Offline Thanks Meter: 148 | VIVO_Y55 firehose_8937 - submitted Quote:
Here is extracted loader from Vivo Y55 firmware.... prog_emmc_firehose_8937_ddr_VIVO_Y55 https://mega.nz/#!sFcxCBaI!gwTNggGG1...1bsy7SSvx0i8Ik Try it, and post result here Br | |
05-14-2017, 12:14 | #3 (permalink) | |
Member: 1810159 Status: Offline Thanks Meter: 256 | Quote:
Its working bro very very thnx | |
05-14-2017, 17:14 | #5 (permalink) | |
No Life Poster Join Date: May 2012 Location: PARADISE ON EARTH(KASHMIR)
Member: 1754881 Status: Offline Sonork: 100.1644926 Thanks Meter: 146 | Quote:
Br....Mirtelecom | |
05-14-2017, 17:35 | #6 (permalink) | |
Member: 1050590 Status: Offline Thanks Meter: 148 | Quote:
Zippyshare.com - prog_emmc_firehose_8937_ddr_VIVO_Y55.mbn Br | |
09-29-2017, 10:33 | #8 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Why not try QcFire v1.2 instead of asking useless questions? Br, Ultimate Multi Tool |
The Following User Says Thank You to U.M.T For This Useful Post: |
