Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 12-05-2021, 15:43   #1 (permalink)
Member: 2792392
Thanks Meter: 14
vivo y73 v2059 dead after rest frp
Operation : MTK One Click
Hold VOL UP + DOWN and connect USB Cable.
Some phone may have different key combination for BROM mode.
Waiting for device in BROM mode...
Port: COM5 [MediaTek USB Port_V1632 (COM5)]
Device Path: \\?\usb#vid_0e8d&pid_0003#5&376aba2d&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Chipset: 0x0813, [MT6785] [Helio G90]
Hardware Info: 0x8A00, 0xCA00, 0x00
Config : [SecureBoot: True] [SLA: False] [DA Auth: True]
MEID: 038CE408BB70FC0FD5D97FAF74F5DB5C
Preparing device...
-- Success!
Preloader saved as : preloader_k85v1_64_211205_193309.bin
DA : MTK_AllInOne_DA.bin
Waiting for Phone in Flash Mode...
Connect Power Off phone within 30 secs...
Port : MediaTek USB Port_V1632 (COM5)
Connected to BROM.
Sending Download Agent...
connect DA end stage: 2, enable DRAM in 1st DA: 0
Connected to Download Agent..
Executing Flashing Task...
Syncing with Target...
Reading Partition Table...
ERROR: Unknown Sector Size or GPT Erased!
Failed! Please retry or update drivers!
Disconnect Battery/Cable and Power On Phone.
[UltimateMTK Ver. 4.6]
now only mtk port try all method to reebot but luck
now device dead
Old 12-06-2021, 06:43   #2 (permalink)
dany_boy's Avatar
Member: 1977629
Thanks Meter: 429
can you try
Preparing device...
-- Success!
Connected to BROM.
now device dead
remove battery from phone
Old 12-18-2021, 17:31   #3 (permalink)
Member: 293267
Thanks Meter: 14
same problem two mobiles vivo y73
Old 12-18-2021, 17:35   #4 (permalink)
Member: 293267
Thanks Meter: 14
log for y73
Port: COM60 [MediaTek USB Port_V1632 (COM60)]
Device Path: \\?\usb#vid_0e8d&pid_0003#6&2838f1dc&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
MEID: EBBEB507EEA0532562B0CF8E06A7AD56
Preparing device...
-- Success!
Preloader saved as : preloader_k85v1_64_211218_200908.bin
DA : DA_MT6785.bin
Using Custom DA!
Port : MediaTek USB Port_V1632 (COM60)
Connected to BROM.
[UltimateMTK Ver. 4.7]
Old 12-28-2021, 11:23   #5 (permalink)
Member: 2130342
Thanks Meter: 33
same problem to me vivo y73 v2059 frp
Port: COM18 [MediaTek USB Port_V1632 (COM18)]
Device Path: \\?\usb#vid_0e8d&pid_0003#5&94b8c27&0&6#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
MEID: 6926E307F914713F0319265465EF0AED
Preparing device...
-- Success!
Preloader saved as : preloader_k85v1_64_211228_131044.bin
Port : MediaTek USB Port_V1632 (COM18)
Connected to BROM.
Old 12-28-2021, 13:01   #6 (permalink)
Member: 335008
Thanks Meter: 57
dead mine too...
Port: COM7 [MediaTek USB Port_V1632 (COM7)]
Device Path: \\?\usb#vid_0e8d&pid_0003#6&12e3c9ed&0&1#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9}
MEID: 402DBBDCAD566B158BBB50D3A3D58AFC
Preparing device...
-- Success!
Preloader saved as : preloader_k85v1_64_211228_171649.bin
Port : MediaTek USB Port_V1632 (COM7)
Connected to BROM.
[UltimateMTK Ver. 4.8]
whats problem with new version ??
i did the same phone with 4.4, phone reseted..but frp will still there, so i tried with new one 4.8, now phone dead....
logs with 4.4
Port: COM7
Port Name: MediaTek USB Port_V1632 (COM7)
Path: \\?\usb#vid_0e8d&pid_0003#6&12e3c9ed&0&1#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
SecureBoot: True
SLA: False
DA Auth: True
Disabling WatchDog...
- Success
Sending Payload data...
- Payload sent
Initiating Control Transfer...
- Done
Waiting for result...
Disable Auth Success
Preloader saved as : preloader_k85v1_64_211228_170019.bin
Connected to BROM.
Storage : UFS
Reading Device Information...
Build Date : Wed Dec 8 18:45:16 CST 2021
Build Flavor : full_k85v1_64-user
Build Desc. : full_k85v1_64-user 11 RP1A.200720.012 eng.compil.20211208.184923 release-keys
Android Ver. : 11
Display ID : RP1A.200720.012 release-keys
Patch Level : 2021-12-01
Userdata is ENCRYPTED
Formatting Userdata...
- Success!
Seeking FRP Data...
Resetting FRP...
- Success!
[UltimateMTK Ver. 4.4]
Old 12-28-2021, 15:48   #7 (permalink)
Member: 2184085
Thanks Meter: 6
The Following User Says Thank You to sivasakthimcs For This Useful Post:
Old 03-16-2022, 14:25   #8 (permalink)
Member: 627678
Thanks Meter: 14
Same problem to Vivo V21e 5g
Port: COM37
Port Name: MediaTek PreLoader USB VCOM_V1632 (Android) (COM37)
Path: \\?\usb#vid_0e8d&pid_2000#7&5c6b24d&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Preloader Mode Detected, Trying to crash...
- Success!
Device Path: \\?\usb#vid_0e8d&pid_0003#7&5c6b24d&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
MEID: F55DD37DC578D288D219927E130570D3
Preparing device...
-- Success!
Preloader saved as : preloader_k85v1_64_220316_163157.bin
Connected to BROM.
[UltimateMTK Ver. 4.9]
Please tell the solution.
Old 03-17-2022, 20:05   #9 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,462
Flash it and repair security by using RPMB.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 03-22-2022, 04:39   #10 (permalink)
Member: 2643730
Thanks Meter: 1,115
Originally Posted by u.m.t View Post
flash it and repair security by using rpmb.
Br,
umt
yes that is the way but should be suppored in umt mtk tool in next update
The Following User Says Thank You to djj007 For This Useful Post:
Old 03-22-2022, 18:58   #11 (permalink)
U.M.T's Avatar
Member: 2465108
We are looking into this issue as it seems something fishy done by vendor to stop exploit we use.
Br,
UMT
Page generated in 0.19965 seconds with 8 queries
