04-25-2019, 19:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | vivo y95 flash failed Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM32) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8937_ddr.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Failed Operation Finished. QcFire Ver. 4.1 |
04-26-2019, 07:14 | #2 (permalink) | |
No Life Poster Join Date: Jul 2012 Location: GSMFABRICA-Team Age: 35
Member: 1785930 Status: Offline Sonork: 100.1685640 Thanks Meter: 4,780 | Quote:
after write this version same error then use Qcfire Version 3.9 Or 4.0 | |
The Following User Says Thank You to Unlockinfo For This Useful Post: |
11-29-2019, 07:40 | #4 (permalink) |
Insane Poster Join Date: Feb 2011 Location: BIRGUNJ NEPAL Age: 34
Member: 1511137 Status: Offline Thanks Meter: 7 | Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1F00B00 [8937] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_029]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Failed Operation Finished. QcFire Ver. 5.0 Plz Help Gsm team mobile auto restarting while charger plug in |
01-02-2020, 06:04 | #7 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Pakistan
Member: 1555233 Status: Offline Thanks Meter: 2,192 | Help |
The Following User Says Thank You to amjadnona For This Useful Post: |
