07-22-2016, 10:31 | #1 (permalink) |
Freak Poster Join Date: Jul 2013
Member: 1980910 Status: Offline Sonork: 100.1650130 Thanks Meter: 35 | ZTE D286 Emergency flash failed Baud Rate : 921600 Device : Lava D286 (ZTE) Operation : Flash [Emergency] Opening Port... OK Preparing Phone... OK Sending Bootloader... Err 0x02 Port Closed. Operation Failed! Time Taken: 00:01 Module Ver. [1.5] Log Saved to Logs\160722_145954.log |
07-22-2016, 10:46 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Check battery, cable, port etc etc. You must use USB 2.0 or 1.0 port. USB version 3 Port will always cause issue. Br, Ultimate Multi Tool |
07-22-2016, 10:47 | #3 (permalink) |
07-22-2016, 10:56 | #4 (permalink) |
Member: 1980910 Status: Offline Sonork: 100.1650130 Thanks Meter: 35 | Thanku for quick reply and I flashed successfully after holding boot key it started flashing with umt now set on and for unlock its showing unsupported firmware Port : COM11 : Qualcomm HS-USB Diagnostics 9004 (COM11) Baud Rate : 921600 Device : Lava D286 (ZTE) Operation : Unlock Opening Port... OK Reading Information... OK Compile : Nov 12 2013 23:42:25 Release : Apr 24 2012 05:00:00 Hw Ver. : UP105D05 ESN : 802508D9 MEID : A000003872B264 IMEI : 862722023089796 BUILD : q11x5-CG108-1030 Reading Extended Information... OK User Code : 0000 SPC : 000000 Unsupported Firmware! Port Closed. Operation Failed! Time Taken: 00:01 Module Ver. [1.5] Log Saved to Logs\160722_152248.log please help |
07-22-2016, 17:29 | #5 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | You must send us firmware to add support for this version. Atm, use firmware from support to flash and unlock it. Br, Ultimate Multi Tool |
07-23-2016, 07:17 | #7 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Please try to flash with Reliance firmware on support. We will add support for this firmware in future update. Br, Ultimate Multi Tool |
