Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 02-04-2018, 19:44   #16 (permalink)
owais a's Avatar
Member: 2401939
Thanks Meter: 186
Originally Posted by MeetMobileWorld View Post
after reset efs imei no 0
then write qcn by qpst tool problem is same as
any solution plz help
reset efs then write qcn and repair imei by umt method 2 then restart device again repair imei by umt method 2 and write qcn
Sent from my Redmi Note 4 using Tapatalk
Old 02-07-2018, 13:51   #17 (permalink)
Member: 1342044
Thanks Meter: 42
Port : COM10 : Qualcomm HS-USB Diagnostics 9091 (COM10)
Baud Rate : 921600
Device : Qualcomm Android
Operation : Write QCN
Opening Port... OK
Reading Phone Information... OK
Compile : Jan 9 2018 10:05:31
Release : Oct 10 2017 05:00:00
Hw Ver. : 8953.gen
Build : MPSS.TA.2.3.c1-00544-8953_GEN_PACK-1
IMEI : 863525024317978
MEID : 99000982061603
Sending SPC [000000]... OK OK
QCN File : mi one (ndi2).qcn
Format : QPST QCN
Restoring QCN Data... Done
Port Closed.
Please reboot phone.
Operation Finished.
Elapsed Time: 01:02
[Module Ver. 4.8]
Log Saved to Logs\180207_193920.log
after imei write same imei nill
Old 02-07-2018, 18:13   #18 (permalink)
owais a's Avatar
Member: 2401939
Thanks Meter: 186
Originally Posted by ushe View Post
Port: COM10 : Qualcomm HS-USB Diagnostics 9091 (COM10)
Baud Rate: 921600
Device: Qualcomm Android
Operation: Write QCN
Opening Port... OK
Compile: Jan 9 2018 10:05:31
Release: Oct 10 2017 05:00:00
Hw Ver.: 8953.gen
Build: MPSS.TA.2.3.c1-00544-8953_GEN_PACK-1
IMEI: 863525024317978
MEID: 99000982061603
QCN File: mi one (ndi2).qcn
Format: QPST QCN
Port Closed.
Operation Finished.
Elapsed Time: 01:02
[Module Ver. 4.8]
use Umt for write qcn then repair imei by umt method 2
Old 02-08-2018, 06:39   #19 (permalink)
Member: 1050364
Thanks Meter: 106
Baud Rate : 921600
Opening Port... OK
Hw Ver. : 8953.gen
Format : QPST QCN
Port Closed.
Operation Finished.
Elapsed Time: 01:02
[Module Ver. 4.8]
flash this file and try again its done press thanks button
tissot_images_7.8.23_20170823.0000.00_7.1_61cf97d7 94
Old 02-15-2018, 12:29   #20 (permalink)
Member: 1129386
Thanks Meter: 2
its shows done but not repaired
Old 02-21-2018, 14:48   #21 (permalink)
Member: 2768374
Originally Posted by owais a View Post
spidersyed your qcn is damaged i try it, i have a good qcn if any one want come in personal message and press thanks button
sir good qnc chahiye MI A1 KA
Old 03-07-2018, 14:46   #22 (permalink)
farooquepm's Avatar
Member: 2424314
Thanks Meter: 234
https://www.4shared.com/rar/bIrXAs2b...ne__mdi2_.html
check and post result here
The Following User Says Thank You to farooquepm For This Useful Post:
Old 05-31-2018, 14:35   #23 (permalink)
Member: 1314806
Sonork: 100.1000
Thanks Meter: 74
i cant imei repair, please help
Old 06-03-2018, 18:13   #24 (permalink)
mcclinic's Avatar
Member: 593876
Thanks Meter: 246
Originally Posted by fahaankhan613 View Post
reset efs with edl mode no need root
your procedure is wrong, im Reset EFS and Mi A1 MDG2 is complete Dead, i loss BDT 12,000. so wrong.
Old 06-03-2018, 18:23   #25 (permalink)
owais a's Avatar
Member: 2401939
Thanks Meter: 186
you lost because of your mistake no one get problem on efs reset procedure, your phone hardware emmc problem check it
Old 07-12-2018, 07:13   #26 (permalink)
Member: 2792308
Sonork: 100.650600
que android tiene el equipo que reparo 8.0 o 7.0?
Old 07-13-2018, 16:12   #27 (permalink)
owais a's Avatar
Member: 2401939
Thanks Meter: 186
english language only please
Old 08-13-2018, 23:46   #28 (permalink)
Member: 1309482
Thanks Meter: 22
Originally Posted by JONONItelecomô View Post
Port : COM46 : Qualcomm HS-USB Diagnostics 9092 (COM46)
Baud Rate : 921600
Operation : Write IMEI [UMT Method [1]]
Opening Port... OK
Compile : Dec 1 2017 15:12:12
Hw Ver. : 8953.gen
Build : MPSS.TA.2.3.c1-00361-8953_GEN_PACK-1.117743.1.119183.2
IMEI [1] : 865?/////////////////
IMEI [2] : 865/////////////////
Method : UMT Method [1]
Preparing Data... Done
Writing IMEI 1 [867655446778766]... Done
Writing IMEI 2 [867755246758784]... Done
Rebooting Phone... Done
Please reboot maunally if does not reboot automatically.
Operation Finished.
Elapsed Time: 00:06
[Module Ver. 4.5]
Log Saved to Logs\171228_182020.log
Hi Bro!. If I have Android 8, I need downgrade the firmware to doo the imei Repair!? Thanks!
Old 08-15-2018, 17:44   #29 (permalink)
Member: 2438408
Thanks Meter: 363
WORLD FIRST MI A1 IMEI REPAIR DONE BY UMT
1) IMEI REPAIR
FISRT RESET EFS THEN REPAIR IMEI FINALLY WRITE A GOOD QCN FILE
2) QCN WRITE
direct repair or write qcn file
Page generated in 0.37790 seconds with 7 queries
