10-17-2018, 23:22 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | Xiaomi flashing need help with some xiaomi, i have three phones, Xiaomi mi 6a with system destroyed? is it possible to repair this one my flashing? also redmi note 4x and redmi mi 5 stuck on mi logo with 3 dots after OTA update, i tryed to flash mi 5 with developer and global fastboot file, flash went ok via edl mode, but always stuck, any ideas? i am learning about xiaomi, best regards |
10-18-2018, 10:57 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | For UFS memory based devices, use Multi Program Mode, there you can select just folder and it will automatically loader all rawprogram files. Try to flash factory firmware and check if it is fixed. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
10-20-2018, 12:16 | #4 (permalink) |
Member: 31028 Status: Offline Thanks Meter: 56 | still the same... tryed with gemini_global_images_V10.0.1.0.OAAMIFH_20180831.00 00.00_8.0_global_4288bc1f30 gemini_global_images_8.10.11_20181011.0000.00_8.0_ global_a9c74f1eb9 still not booting, any ideia? is there any other versions? best regards |
10-20-2018, 12:19 | #6 (permalink) |
Member: 31028 Status: Offline Thanks Meter: 56 | Operation : Multi Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM77) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1709400 [8996] 00000000 OPK_DATA : 65D680382C4E0091ED2A1DDCD7EFD99ED328BEBDAD748E5CE1 77EC5AB6544AE5 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_002]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, UFS, 32 GB LU Count : 6 [0x00654C00] [0x00000400] [0x00000400] [0x00008000] [0x00114000] [0x00002000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 4096 Processing [rawprogram0.xml] Writing [dummy.img] -> [switch] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [misc.img] -> [misc] ...Done Writing [persist.img] -> [persist] ...Done Writing [cache.img] -> [cache] ...Done Writing [userdata.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram1.xml] Writing [xbl.elf] -> [xbl] ...Done Writing [gpt_main1.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup1.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram2.xml] Writing [xbl.elf] -> [xblbak] ...Done Writing [gpt_main2.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup2.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram3.xml] Writing [gpt_main3.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup3.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram4.xml] Writing [pmic.elf] -> [pmic] ...Done Writing [pmic.elf] -> [pmicbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [logo.img] -> [logo] ...Done Writing [adspso.bin] -> [dsp] ...Done Writing [splash.img] -> [splash] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cust.img] -> [cust] ...Done Writing [system.img] -> [system] ...Done Writing [gpt_main4.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup4.bin] -> [BackupGPT] ...Done Applying Patches................Done Processing [rawprogram5.xml] Writing [gpt_main5.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup5.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. |
10-20-2018, 18:15 | #7 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Log shows successful flashing including persist and userdata. Make sure you are using firmware for correct variant, for example, China and Global. Br, UMT |
