03-14-2019, 20:38 | #2 (permalink) |
Banned Join Date: Sep 2016 Location: living on the edge
Member: 2620145 Status: Offline Thanks Meter: 319 | bro change rome the i don it with old security poco f1 Operation : Mi Anti Relock Checking for device in ADB mode...Found! Searching for Device...Found Brand : Xiaomi Model : POCOPHONE F1 Product : beryllium Device : beryllium Andriod Ver. : 8.1.0 Patch Level : 2018-07-01 Bootloader : unknown Build ID : OPM1.171019.011 Build Date : Mon Jul 30 21:49:21 WIB 2018 Disabling Mi Account Relock...Verified OK... Done Operation Finished. QcFire Ver. 3.9 |
03-15-2019, 17:34 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | Thank you but still can`t figure it out Persist write is ok, phone discovers all wifi networks and still locked but Reset Mi Acc does not work again 24 hour near me |
03-15-2019, 20:11 | #8 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | I guess it was a driver issue. Installed an older qcomm driver and it worked Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro Software : OPM1.171019.011, V9.6.8.0.OEKMIFD [Wed Sep 5 11:06:54 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-08-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 3.9 |
The Following User Says Thank You to tintome For This Useful Post: |
03-15-2019, 21:06 | #9 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | Still, with this driver persist.img can`t be written Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iLz4KPC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIC8+CjwvZG F0YT5= Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 3.9 |
03-16-2019, 09:50 | #11 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | Yes, after leaving without battery connector over night, this morning worked from the first try. Persist written ok , wifi working but phone re-locked after 2 minutes of wifi :| What am I not doing right ? Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Trying Mi Account Relock Patch.....OK Writing [persist.img] -> [persist] ...Done Applying Patches................Done Resetting device...Done Operation Finished. |
03-16-2019, 10:22 | #12 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | First step : Reset Mi account (phone re-locked, I hit YES) Device : Xiaomi Redmi Note 6 Pro Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 6 Pro Software : OPM1.171019.011, V9.6.8.0.OEKMIFD [Wed Sep 5 11:06:54 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-08-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 3.9 |
03-16-2019, 10:44 | #13 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | After this no WIFI I activate adb and do antirelock Operation : Mi Anti Relock Checking for device in ADB mode...Found! Searching for Device...Found Brand : xiaomi Model : Redmi Note 6 Pro Product : tulip Device : tulip Andriod Ver. : 8.1.0 Patch Level : 2018-08-01 Bootloader : unknown Build ID : OPM1.171019.011 Build Date : Wed Sep 5 11:06:54 CST 2018 Disabling Mi Account Relock...Verified OK... Done Operation Finished. QcFire Ver. 3.9 |
03-16-2019, 10:49 | #14 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | After this I always receive this error: Waiting for debugger Application Find Device (process com.xiaomi.finddevice) is waiting for the debugger to attach. force close |
03-16-2019, 11:54 | #15 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: Internet
Member: 444091 Status: Offline Thanks Meter: 21 | Quote:
Function of Mi Anti Relock = remove find device apps That's mean system will always pop-up that message & it's common issue. | |
