09-24-2018, 07:12 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: india
Member: 699762 Status: Offline Thanks Meter: 66 | Xiaomi Redmi 4X how to read pattern if i reset lock data delet or not help Operation : Read Pattern Lock Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM50) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1B00600 [8937] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8937_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 4X [msm8937] Software : MMB29M, V8.2.12.0.MAMMIEA [Thu Jun 29 20:09:51 WIB 2017] Android Ver. : 6.0.1 Patch Level : 2017-05-01 Android 6.x and higher are not supported, please use [Reset Locks] function. |
09-24-2018, 07:15 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Reset Locks will not delete data. But it will not work if Userdata is Encrypted. In such case, you can use Disable Locks, then backup your data and then Restore Locks so phone will be back to its initial stage. Then you can Factory Reset as you have already backup your data. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
