Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 01-23-2020, 22:20   #1 (permalink)
Member: 1690056
Thanks Meter: 103
Xiaomi Redmi Note 6 Pro remove mi account done but wifi not working
hi
Operation : Reset Mi Account
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM92)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1C00C00 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8996_016]...Done
Executing Loader...OK
Detecting Chip Type...OK
Hardware : MSM8996, eMMC, 64 GB
LU Count : 1 [0x0747C000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi Redmi Note 6 Pro [tulip]
Software : PKQ1.180904.001, V10.3.3.0.PEKMIXM [Tue May 14 21:24:37 WIB 2019]
Android Ver. : 9
Patch Level : 2019-05-05
Resetting Mi Account Data...Done
Preparing Data...Done
Formatting Userdata...Done
When phone is completely ON, connect to Internet and add Mi Account.
Operation : Disable Mi Account
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM92)
Connecting to phone...OK
Waiting for response...Ignored
Operation : Reset FRP
Opening Port...OK
Android Ver. : 9
Resetting FRP Lock.......Done
Operation Finished.
QcFire Ver. 5.2
Operation : Mi Anti Relock
Checking for device in ADB mode...Found!
Searching for Device in ADB Mode...Found
Brand : xiaomi
Model : Redmi Note 6 Pro
Product : tulip
Device : tulip
Andriod Ver. : 9
Bootloader : unknown
Build ID : PKQ1.180904.001
Build Date : Tue May 14 21:24:37 WIB 2019
Disabling Mi Account Relock...Verified OK... Done
Operation Finished.
QcFire Ver. 5.2
mi account is remouved but wifi not work
Old 01-23-2020, 22:48   #2 (permalink)
Member: 2682773
Thanks Meter: 50
Reflash PERSIST (only) partition - WiFi should start working properly.
The Following User Says Thank You to zexon72 For This Useful Post:
Old 01-25-2020, 12:42   #3 (permalink)
Member: 1690056
Thanks Meter: 103
slm
wifi resolved but mi account relock
Operation : Flash
Waiting for response...OK
Writing [GD_Mekail92.img] -> [frp] ...Done
Writing [persist.img ] -> [persist]...Done
Applying Patches................Done
Resetting device...Done
Operation Finished.
QcFire Ver. 5.2
Old 01-25-2020, 14:32   #4 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
Downgrade and unlock bootloader.
And then flash custom ROM.
Br,
UMT
The Following 3 Users Say Thank You to U.M.T For This Useful Post:
Old 02-02-2020, 02:59   #5 (permalink)
Member: 1690056
Thanks Meter: 103
Br,
UMT
slm
after flash boot patch and unlock bootloader the phone start black screen
how repair please
Operation : Xiaomi Boot Patch
Found Port : Qualcomm HS-USB QDLoader 9008 (COM56)
Android Ver. : 9
Processing Redmi_Note7........Done
Rebooting to Fastboot...Done
Put phone in Fastboot mode if it is not in Fastboot Mode.
Then try Unlock BL in Fastboot Mode.
Operation Finished.
QcFire Ver. 5.2
Operation : Bootloader Unlock (Fastboot)
Searching for Device in FastBoot Mode...OK
Reading Information...OK
FastBoot Ver. : GetVar Variable Not found
Product : wayne
Bootloader : Locked
Unlocking Bootloader...Done
QcFire Ver. 5.2
Old 02-02-2020, 07:39   #6 (permalink)
Member: 2646627
Thanks Meter: 11
earlier log says tulip and last log says wayne... just flashing a note 6 pro tulip firmware should solve your problem..
Old 02-02-2020, 10:53   #7 (permalink)
U.M.T's Avatar
Member: 2465108
Originally Posted by soltacom View Post
slm
how repair please
Android Ver. : 9
Operation Finished.
QcFire Ver. 5.2
Product : wayne
Bootloader : Locked
QcFire Ver. 5.2
Simply flash it with tulip firmware using Fastboot mode in QcFire.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 02-02-2020, 11:31   #8 (permalink)
Member: 215919
Thanks Meter: 37
When doing mi account or imei repair on xiaomi devices, always back up the efs file of the device, when wifi problem occurs, the efs file is restored to restore
The Following User Says Thank You to tuncaykaraman For This Useful Post:
Page generated in 0.24285 seconds with 8 queries
