04-19-2019, 06:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Xiaomi Redmi Note 7 mi account remove done with great UMT box Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM31) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 7 Software : PKQ1.180904.001, V10.2.3.0.PFGEUXM [Tue Feb 19 23:34:13 CST 2019] Android Ver. : 9 Patch Level : 2019-01-05 Resetting Mi Account Data...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 4.1 Thanks UMT BOX |
The Following 19 Users Say Thank You to pintu_das For This Useful Post: |
04-21-2019, 11:22 | #3 (permalink) | |
Junior Member Join Date: Oct 2009
Member: 1144512 Status: Offline Thanks Meter: 6 | Quote:
I hope Its disabled | |
The Following 3 Users Say Thank You to alaminbg For This Useful Post: |
05-03-2019, 12:21 | #8 (permalink) |
Major Poster Join Date: Apr 2011 Location: BARCELONA SPAIN
Member: 1551270 Status: Offline Sonork: 1646522 Thanks Meter: 7 | not working redmi note 7 hy i am trying to do but giving erorr loader not sent or if select loader from firmware need sighned loader how you have done can you please share full guide thanx Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM88) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogT25seSBub3Ag YW5kIHNpZyB0YWcgY2FuIGJlIHJlY2V2aWVkIGJlZm9yZSBhdX RoZW50aWNhdGlvbi4iLz4KPC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIC8+CjwvZG F0YT5= Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.0 |
The Following User Says Thank You to raza_2010 For This Useful Post: |
05-04-2019, 14:33 | #10 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | After connect wifi it will be relock 100% tested by me if phone is lost |
The Following 3 Users Say Thank You to SR9 For This Useful Post: |
