Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 05-06-2019, 20:03   #16 (permalink)
Member: 778759
Thanks Meter: 2
Originally Posted by wilfera View Post
i have same problem,after remove mi account wifi and imei lost
advance flash
conect test point EDL
write only archive persist
wifi back
Old 05-07-2019, 20:08   #17 (permalink)
Member: 1894819
Thanks Meter: 16
Originally Posted by hacker gsm View Post
advance flash
wifi back
Operation : Flash
Checking for existing devices...Not Found
Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable.
Some phones may need Special Boot Cable or TestPoint for EDL mode.
Found Port : Qualcomm HS-USB QDLoader 9008 (COM19)
Driver Info : Network Connect, qcusbser.sys, 3.0.0.0
Connecting to phone...OK
Waiting for response...OK
Init Handshake Sequence...OK
Hardware ID : E1C00800 [8996] 00000000
OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1
Initializing Protocol...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [8996_022]...Done
Executing Loader...OK
Detecting Chip Type...Failed
VIP Enabled / Auth Enabled Device!
Please use correct loader and check USB port / cable.
Operation Finished.
QcFire Ver. 4.1
Old 06-21-2019, 00:15   #18 (permalink)
Crazy Poster
Member: 2787994
Thanks Meter: 2
if it is possible to remove my account to redmi note 7 and note 7 pro updated to miui 10 ???? ???
Old 06-21-2019, 02:41   #19 (permalink)
rorm's Avatar
Member: 593158
Thanks Meter: 15
Not downgrade miui 10 to miui 9.0, stop downgrade, arb4 and arb5
The Following User Says Thank You to rorm For This Useful Post:
Old 06-23-2019, 13:27   #20 (permalink)
Crazy Poster
Member: 1324837
Sonork: jisankhan
Thanks Meter: 58
Device : Xiaomi Redmi Note 7
Operation : Reset Mi Account
Found Port : Qualcomm HS-USB QDLoader 9008 (COM17)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Detecting Chip Type...OK
Hardware : MSM8996, eMMC, 64 GB
LU Count : 1 [0x0747C000]
WARNING! High Speed Driver is not installed.
Please install driver from QcFire\Drivers folder using Device Manager.
Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512
Reading Partition Table...OK
Reading Device Information...OK
Device : Xiaomi Redmi Note 7 [lavender]
Software : PKQ1.180904.001, V10.3.2.0.PFGEUXM [Thu Apr 25 18:17:56 WIB 2019]
Android Ver. : 9
Patch Level : 2019-04-05
Resetting Mi Account Data...Done
When phone is completely ON, connect to Internet and add Mi Account.
-------------- INFORMATION --------------
New Firmware may cause hang on logo.
In such case, you need to flash phone to recover.
Or downgrade firmware and try Reset Mi Account again.
Operation Finished.
QcFire Ver. 4.3
NOTE: WIFI NOT WORKING.
Old 06-28-2019, 01:58   #21 (permalink)
Member: 1728807
Sonork: 1669717
Thanks Meter: 21
hello friends
All devices updated to android pie 9.0 not supported Anti-Re-lock option
when i remove the account and connect wifi the device re-locked again
any one have a solution to disable find my device using adb command on android pie 9.0?
thxx
The Following 2 Users Say Thank You to Mohammad Thabet For This Useful Post:
Old 06-28-2019, 10:07   #22 (permalink)
teokarafou's Avatar
Member: 2578145
Thanks Meter: 116
downgrade to 10.2 miui then mi account disable then anti-relock
Old 07-01-2019, 10:57   #23 (permalink)
Member: 2111301
Sonork: 1651880:UzjavaAzizbek
Thanks Meter: 63
Originally Posted by limonbogra View Post
1st mi ac reset then . anti relock (adb mode)
not working antirelock with miui10.3(android 9)
The Following User Says Thank You to UzjavaAzizbek For This Useful Post:
Old 07-05-2019, 22:40   #24 (permalink)
Member: 2769447
Thanks Meter: 9
Redmi Note 7, Redmi 6 pro - UMT do not to unlock! mi acc still here!(
Old 07-15-2019, 13:13   #25 (permalink)
samb-nd-ct's Avatar
Member: 289229
Sonork: samb-nd-ct
Thanks Meter: 195
my problem is
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM236)
Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0
Opening Port...OK
Auth Enabled Device! You need Mi Auth Account to service!
Reading Auth Blob...Failed
Storage Initializaton Failed!
Operation Finished.
QcFire Ver. 4.5
Old 07-16-2019, 06:54   #26 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,363
Originally Posted by samb-nd-ct View Post
my problem is
Opening Port...OK
Operation Finished.
QcFire Ver. 4.5
bro you need mi auth account to service
if you don't have mi auth account try to UMTv2_UMTPro_QcFire_v4.3_Setup.exe
Old 07-16-2019, 09:29   #27 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,430
No need of v4.3.
Auth is required only if phone asks for AUTH, software does not force for AUTH.
Br,
UMT
The Following User Says Thank You to U.M.T For This Useful Post:
Old 08-22-2019, 17:30   #28 (permalink)
Member: 2590090
Thanks Meter: 4
how to enter edl mode !! please
redmi note 7
Old 12-19-2019, 15:49   #29 (permalink)
Member: 2738117
not worcking antirelock miui 10.2.1 (factory)
Old 01-07-2020, 14:12   #30 (permalink)
Member: 2243791
Thanks Meter: 9
redmi 7 bootloader not unlocking after buying umt xiomi auth credit .......umt 5.1 saying server offline and umt 4.9 saying connection error.. UMT PLEASE HELP
Page generated in 0.22038 seconds with 8 queries
