Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 09-10-2020, 09:50   #1 (permalink)
Member: 2682773
Thanks Meter: 50
Xiaomi SERVER UNDER MAINTENANCE
The authorization server, despite the ONLINE status, throws an error - SERVER UNDER MAINTENANCE.
Operation: Flash witch Multi Flash Xioami Mi9 cepheus
Find device status: OFF
Tested on QcFire 6.0 and 5.9
Operation	: Multi Flash
Checking for existing devices...Found
Port	: Qualcomm HS-USB QDLoader 9008 (COM3)
Driver Info	: Qualcomm Incorporated, qcusbser.sys, 2.1.2.2
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID	: E1500A00 [SD855] 00007200
OPK_DATA	: 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7
Initializing Protocol...OK
Sending Loader [prog_ufs_firehose_sdm855_ddr.elf]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Requesting UMT Auth Service (FREE)...Failed
Error Log	: PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogQmxvYiBzaG91bGQgaW5pdCBmaXJzdC4iIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIHJhd21vZGU9ImZhbHNlIiAvPjwvZGF0YT5=
Reading Auth Blob...OK
Blob	: NDE1MTQxNDE0MTQ2NEQ0MjQxNDE0Mjc2NTYzNjZFNjY2NzU0NzQ1QTMwNjY1Mzc4NDc1NjY5NjY0Mjc2NjI2RDZENEMzODc1NEM0MU==
Requesting UMT Server for Auth Data...SERVER_UNDER_MAINTENANCE
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
Operation Failed.
QcFire Ver. 6.0
Opening Port...OK
Blob	: NDE1MTQxNDE0MTQ2NEQ0MjQxNDE0Mjc2NTYzNjZFNjY1MjU1NUY0MTMxNEU1NjQ2Nzk0NDZCNTY0QjZBNTc0MzU5NUY2RTM5NTE0MT==
Operation Failed.
QcFire Ver. 5.9
Old 09-10-2020, 15:29   #2 (permalink)
Member: 1001450
Thanks Meter: 28
same problem please help umt team !!!
Old 09-10-2020, 16:02   #3 (permalink)
Member: 1740985
Thanks Meter: 4
I'm having the same problem
Old 09-10-2020, 19:32   #4 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
It is temporary, and only when server is exhausted for the day.
It is back normal. If you ever face such issue, please retry after a few hours.
If in case, server is offline for days, you will definitely see another message.
Br,
UMT
Old 09-11-2020, 09:45   #5 (permalink)
Member: 1001450
Thanks Meter: 28
Br,
UMT
I've been trying since last night, it doesn't workI've been trying since last night, it doesn't work
Old 09-11-2020, 12:43   #6 (permalink)
Member: 2682773
Thanks Meter: 50
I confirm - it still does not work.
Old 09-11-2020, 12:48   #7 (permalink)
Member: 2771307
Thanks Meter: 772
Then just wait 24h and try again. No need try every hour. Limit is reseted 1 time per day then need wait at least 24h.
Old 09-12-2020, 21:35   #8 (permalink)
Member: 2593816
ayer lo probe y espere un dia y me dice lo mismo
Old 09-12-2020, 22:59   #9 (permalink)
Member: 1820429
Thanks Meter: 57
umt has said it when the server is exhausted, you have to grab it early in the morning that I'm not tired to see if you're lucky I've been 4 days I haven't achieved even one
Old 09-14-2020, 08:12   #10 (permalink)
Member: 582064
Thanks Meter: 14
It worked today morning. Thanks.
Old 09-14-2020, 15:33   #11 (permalink)
Member: 1649310
Hi I also have this error for three days " SERVER_UNDER_MAINTENANCE"
Old 09-14-2020, 15:45   #12 (permalink)
Member: 1649310
in the morning at what time is it advisable to try Moscow time at my place
Old 09-15-2020, 08:44   #13 (permalink)
Member: 2682773
Thanks Meter: 50
Sorry, but naming things as they are - it's not a funny joke!
Since Friday, I'm trying to make a flash Mi9 with authorization and you tell me to wait 24 hours - I waited 48 hours and nothing.
If you want your tool to be taken seriously - then treat us as clients seriously, not as beggars.
If the server has problems with performance - change it to a more efficient one, in the end we pay for the service. I am willing to pay $ 20 for an authorization as long as it works !!!
Sorry for the sharp statement - but I think that most of the disappointed customers think the same.
The Following User Says Thank You to zexon72 For This Useful Post:
Old 09-15-2020, 09:14   #14 (permalink)
Member: 582064
Thanks Meter: 14
For me MI 9, MIX 3 and others are waiting 2 days now.
Old 09-15-2020, 17:30   #15 (permalink)
Member: 1649310
I can't flash it for the fourth day error " SERVER_UNDER_MAINTENANCE"
Page generated in 0.22041 seconds with 8 queries
