09-10-2020, 09:50 | #1 (permalink) |
Insane Poster Join Date: Feb 2017 Location: Czestochowa, Poland
Member: 2682773 Status: Offline Thanks Meter: 50 | Xiaomi SERVER UNDER MAINTENANCE Operation: Flash witch Multi Flash Xioami Mi9 cepheus Find device status: OFF Tested on QcFire 6.0 and 5.9 Code: Operation : Multi Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1500A00 [SD855] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_ufs_firehose_sdm855_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Requesting UMT Auth Service (FREE)...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogQmxvYiBzaG91bGQgaW5pdCBmaXJzdC4iIC8+PC9kYXRhPjw/eG1sIHZlcnNpb249IjEuMCIgZW5jb2Rpbmc9IlVURi04IiA/Pgo8ZGF0YT4KPHJlc3BvbnNlIHZhbHVlPSJOQUsiIHJhd21vZGU9ImZhbHNlIiAvPjwvZGF0YT5= Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2NEQ0MjQxNDE0Mjc2NTYzNjZFNjY2NzU0NzQ1QTMwNjY1Mzc4NDc1NjY5NjY0Mjc2NjI2RDZENEMzODc1NEM0MU== Requesting UMT Server for Auth Data...SERVER_UNDER_MAINTENANCE Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Failed. QcFire Ver. 6.0 Code: Operation : Multi Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1500A00 [SD855] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_ufs_firehose_sdm855_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2NEQ0MjQxNDE0Mjc2NTYzNjZFNjY1MjU1NUY0MTMxNEU1NjQ2Nzk0NDZCNTY0QjZBNTc0MzU5NUY2RTM5NTE0MT== Requesting UMT Server for Auth Data...SERVER_UNDER_MAINTENANCE Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Failed. QcFire Ver. 5.9 |
09-10-2020, 19:32 | #4 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | It is temporary, and only when server is exhausted for the day. It is back normal. If you ever face such issue, please retry after a few hours. If in case, server is offline for days, you will definitely see another message. Br, UMT |
09-12-2020, 22:59 | #9 (permalink) |
Freak Poster Join Date: Oct 2012 Location: transilvania
Member: 1820429 Status: Offline Thanks Meter: 57 | umt has said it when the server is exhausted, you have to grab it early in the morning that I'm not tired to see if you're lucky I've been 4 days I haven't achieved even one |
09-15-2020, 08:44 | #13 (permalink) | |
Member: 2682773 Status: Offline Thanks Meter: 50 | Quote:
Since Friday, I'm trying to make a flash Mi9 with authorization and you tell me to wait 24 hours - I waited 48 hours and nothing. If you want your tool to be taken seriously - then treat us as clients seriously, not as beggars. If the server has problems with performance - change it to a more efficient one, in the end we pay for the service. I am willing to pay $ 20 for an authorization as long as it works !!! Sorry for the sharp statement - but I think that most of the disappointed customers think the same. | |
The Following User Says Thank You to zexon72 For This Useful Post: |
