08-22-2018, 00:06 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Lagos Nigeria
Member: 61176 Status: Offline Sonork: 100.86572 Thanks Meter: 368 | zte encrypted userdata help Operation : Reset Locks Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM91) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.0.3 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1209700 [8952] 00000400 OPK_DATA : 46B4EC5C949D2BD3FA853DFEDEE69DF9F6B7415FADA68A0729 345ADC932CB23F Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Firehose Loader...Done Sending Loader [8952_016.ufl]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8952, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...Failed USERDATA : Encrypted Encrypted USERDATA is NOT SUPPORTED Operation Failed. Module Ver. 2.6 how to unlock? |
08-22-2018, 18:42 | #3 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Try Disable Locks and see if it works. If yes, then backup data when lock is disabled. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
