06-24-2017, 17:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | Zte max pro zte z981 loader needed msm8952 {{check inside team 4 more info}} Checking for existing devices... Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone... OK Waiting for response... OK Init Handshake Sequence... OK Hardware ID : E1209700 [8952] 00000400 Initializing Protocol... OK Using Auto Selection Preparing Firehose Loader... Done Sending Loader [8952_3.ufl]... Write Error! Please use correct loader and check USB port / cable. Module Ver. 0.9 WILL BE GLAD IF ADDED NEXT VERSION OR ANYONE CAN PROVIDE ME LOADER.. |
07-07-2017, 13:12 | #4 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2529558 Status: Offline Thanks Meter: 0 | hi i need help with my ZTE Zmax Pro z981. The mobile data is not working but the phone does pick local network. I can make call and text messages but i can only use wifi on the phone and not mobile data meanwhile i have set the right APN for my local network yet it is not working. can someone please help me out with that please |
12-04-2017, 07:34 | #7 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1209700 [8952] 00000400 OPK_DATA : 5662CAD0CFCCC2090245A6E87006CBAAECF28FAE81C62246BC C25820C5146F8E Initializing Protocol...OK Sending Loader [Qualcomm_Factory_Loader_MSM8952_Zte.mbn]...Write Error! Please use correct loader and check USB port / cable. Module Ver. 1.2 |
The Following User Says Thank You to srkhan For This Useful Post: |
