ASUS Fonepad 7 K012 (FE170CG) Update Solution! Hey Guys, Today i'm gonna show you how to solve SD update problem for ASUS K012, I was suffering from that problem for a while and tried almost EVERYTHING, The problem is that SD Update always FAIL, #let's begin, First of all you have to identify what FW ver you have, 1. Start the TAB in Droidboot by pressing and HOLDING Volume UP and Power button until the menu appears, 2. Now you can see what FW Installed on your TAB, http://www.egylovers.net/news/wp-con...6022897207.jpg 3. Now go to ASUS Support Site and Download the same FW as your TAB, http://www.egylovers.net/news/wp-con...0599739574.jpg 4. After Downloading FW, Extract it and Copy .zip File to SD Card and rename it to k012_sdupdate.zip, 5. Now put back SD Card into TAB and Reboot into DroidBoot Mode, 6. Now Here is the Trick, You have to Plug the Charger in the TAB while Updating from SD So, Plug the Charger now then choose SD Update, 7. Wait until Update process finish then reboot your TAB, >>DONE<< #In case that guide didn't help you solve your problem try this one, 1. Extract this files from the FW zip file and copy them to fastboot folder, Code: fastboot.img Code: fastboot erase cache 4. Put back SD Card into TAB and Reboot into DroidBoot then Plug Charger and Select SD Update, >>DONE<< NOTE: SOLUTION TESTED BY ME MANY TIMES AND I'VE FIXED MORE THAN 10-TABS. |
and here is another TAB .. http://i.imgur.com/posWIsB.jpg |
Not work Brother 80% Error Update iNeed Solution |
Sent from my SM-G7102 using Tapatalk |
As i said, solution tested by me many times and it works, Maybe you flashed (fastboot, boot and splashscreen) from another FW ver .. Not the one was installed on the tablet, So, now try to flash all 3 .img from another FW ver and i recommend (10.32.1.33.1) which is a JellyBean 4.3, After that use this command to reboot into DroidBoot mode, fastboot reboot-bootloader Now you see SD Update, Follow the guide and you shall have your TAB fixed. BR Sent from my iPhone 6 using Tapatalk. |
Glad that i could help .. :) And thank you for your feedback ,, BR Sent from my iPhone 6 using Tapatalk. |
As i said, solution tested by me many times and it works, Maybe you flashed (fastboot, boot and splashscreen) from another FW ver .. Not the one was installed on the tablet, So, now try to flash all 3 .img from another FW ver and i recommend (10.32.1.33.1) which is a JellyBean 4.3, After that use this command to reboot into DroidBoot mode, fastboot reboot-bootloader Now you see SD Update, Follow the guide and you shall have your TAB fixed..................a very big thanks... my problem solve....this soution is tested |
Hi there, i need your help! I have root asus fonepad 7 170cg k012, and i click to instal 5.0 (i get notification for update) Then my tablet is turn off and all time when i turn on this show me andorid logo and ERROR.. I try to follow all of your method but nothnig.. My spec: DROITBOOT PROVISIO OS IFWI VERSION: 64.25 SERIAL_NUM: E70KBC296334 DROITBOOT VERSION: WW_fonepad-11.2.3.34-20150302 PRODUCT: K012 When i conect my tablet to pc i cant fastboot (waiting phone) I dont see SD UPDATE on DROIDBOOT menu.. |
Hello my dear friends who can tell me is k012 can call with 2 sim there is one that can coll only by 1 sim when I want do coll by 2 sim it tell me that no netwark.And also tell me please this have 2 imeis or 1? |
i dont see sdupdate menu.... only recovery but can't see update progress, have tried to rename bundle or k012 |
C:\Documents and Settings\Maison De GSM>C:/fastboot flash fastboot fastboot.img target reported max download size of 157286400 bytes error: cannot load 'fastboot.img': Unknown error C:\Documents and Settings\Maison De GSM>C:/fastboot flash boot boot.img target reported max download size of 157286400 bytes error: cannot load 'boot.img': Unknown error :confused: what problem and how i can solve my tablet already have version 10.32.1.33.1 and i try with some version |
asus logo only not going to droidboot mode vol+ power only logo how can recover? |
WW-11.2.3.18.2 after write... fastboot erase cache fastboot erase system fastboot erase userdata fastboot flash fastboot fastboot.img fastboot flash boot boot.img fastboot flash splashscreen splashscreen.img SD Update Not Show, how To solved? Need Solution |
