Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > ASUS
ASUS ASUS Devices
Old 08-20-2015, 22:44   #1 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 797
Lightbulb ASUS Fonepad 7 K012 (FE170CG) Update Solution!
Hey Guys,
Today i'm gonna show you how to solve SD update problem for ASUS K012,
I was suffering from that problem for a while and tried almost EVERYTHING,
The problem is that SD Update always FAIL,
#let's begin,
First of all you have to identify what FW ver you have,
1. Start the TAB in Droidboot by pressing and HOLDING Volume UP and Power button until the menu appears,
2. Now you can see what FW Installed on your TAB,
3. Now go to ASUS Support Site and Download the same FW as your TAB,
4. After Downloading FW, Extract it and Copy .zip File to SD Card and rename it to k012_sdupdate.zip,
5. Now put back SD Card into TAB and Reboot into DroidBoot Mode,
6. Now Here is the Trick, You have to Plug the Charger in the TAB while Updating from SD So, Plug the Charger now then choose SD Update,
7. Wait until Update process finish then reboot your TAB,
>>DONE<<
#In case that guide didn't help you solve your problem try this one,
1. Extract this files from the FW zip file and copy them to fastboot folder,
fastboot.img
boot.img
splashscreen.img
2. Start your TAB in DroidBoot mode and via Fastboot excute this commands one by one,
fastboot erase cache
fastboot erase system
fastboot erase userdata
fastboot flash fastboot fastboot.img
fastboot flash boot boot.img
fastboot flash splashscreen splashscreen.img
3. Now Copy the same .zip File that you've extracted 3 .img files from to SD Card and rename it to k012_sdupdate.zip and Copy it again to the same SD Card but this time rename it to ASUS_BUNDLE.zip,
4. Put back SD Card into TAB and Reboot into DroidBoot then Plug Charger and Select SD Update,
>>DONE<<
NOTE: SOLUTION TESTED BY ME MANY TIMES AND I'VE FIXED MORE THAN 10-TABS.
The Following 12 Users Say Thank You to MiRoOo For This Useful Post:
Old 08-20-2015, 23:06   #2 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 797
Originally Posted by DouglasDou View Post
Very Nice the is the right solution
Thanks my dear
You're so welcome bro ..
and here is another TAB ..
The Following 3 Users Say Thank You to MiRoOo For This Useful Post:
Old 08-21-2015, 03:48   #3 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,595
Details Info
ASUS-FAQ (Update Manual/Informatione/Flash/Wipe ETC)
All About Asus
Old 08-21-2015, 17:06   #4 (permalink)
Esso Elkordy's Avatar
Member: 1823028
Sonork: 100.1622702
Thanks Meter: 42
Not work Brother 80% Error Update iNeed Solution
The Following User Says Thank You to Esso Elkordy For This Useful Post:
Old 08-21-2015, 17:09   #5 (permalink)
Member: 367220
Thanks Meter: 27
Me to kordy this is the tab that i told u b4 remember i am Mohamed Farouk
Sent from my SM-G7102 using Tapatalk
The Following User Says Thank You to mohamedFarouk For This Useful Post:
Old 08-21-2015, 17:14   #6 (permalink)
Member: 367220
Thanks Meter: 27
If u havr good recovery mod { not restart after a few seconds } u can use adbshell push file.zip to internal storage
Old 08-21-2015, 17:41   #7 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 797
As i said, solution tested by me many times and it works,
Maybe you flashed (fastboot, boot and splashscreen) from another FW ver .. Not the one was installed on the tablet,
So, now try to flash all 3 .img from another FW ver and i recommend (10.32.1.33.1) which is a JellyBean 4.3,
After that use this command to reboot into DroidBoot mode,
fastboot reboot-bootloader
Now you see SD Update,
Follow the guide and you shall have your TAB fixed.
Sent from my iPhone 6 using Tapatalk.
Old 08-21-2015, 21:01   #8 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 797
Glad that i could help ..
And thank you for your feedback ,,
The Following User Says Thank You to MiRoOo For This Useful Post:
Old 08-26-2015, 01:16   #9 (permalink)
Member: 2050096
Follow the guide and you shall have your TAB fixed..................a very big thanks... my problem solve....this soution is tested
The Following User Says Thank You to wendel_tech For This Useful Post:
Old 09-03-2015, 07:53   #10 (permalink)
Member: 2141166
Hi there, i need your help!
I have root asus fonepad 7 170cg k012, and i click to instal 5.0 (i get notification for update)
Then my tablet is turn off and all time when i turn on this show me andorid logo and ERROR..
I try to follow all of your method but nothnig..
My spec:
DROITBOOT PROVISIO OS
IFWI VERSION: 64.25
SERIAL_NUM: E70KBC296334
DROITBOOT VERSION: WW_fonepad-11.2.3.34-20150302
PRODUCT: K012
When i conect my tablet to pc i cant fastboot (waiting phone)
I dont see SD UPDATE on DROIDBOOT menu..
Old 09-22-2015, 08:37   #11 (permalink)
Member: 421947
Sonork: 100:1658491
Thanks Meter: 170
Hello my dear friends who can tell me is k012 can call with 2 sim there is one that can coll only by 1 sim when I want do coll by 2 sim it tell me that no netwark.And also tell me please this have 2 imeis or 1?
Old 09-29-2015, 13:06   #12 (permalink)
Member: 1784151
Sonork: 0
Thanks Meter: 71
i dont see sdupdate menu.... only recovery but can't see update progress, have tried to rename bundle or k012
Old 03-21-2017, 15:46   #13 (permalink)
Member: 411207
Thanks Meter: 147
C:\Documents and Settings\Maison De GSM>C:/fastboot flash fastboot fastboot.img
target reported max download size of 157286400 bytes
error: cannot load 'fastboot.img': Unknown error
C:\Documents and Settings\Maison De GSM>C:/fastboot flash boot boot.img
error: cannot load 'boot.img': Unknown error
what problem and how i can solve
my tablet already have version 10.32.1.33.1 and i try with some version
Old 05-31-2017, 08:19   #14 (permalink)
Member: 1309770
asus logo only not going to droidboot mode vol+ power only logo how can recover?
Old 08-18-2017, 10:30   #15 (permalink)
yudibanjar's Avatar
Member: 713923
Thanks Meter: 26
WW-11.2.3.18.2
after write...
SD Update Not Show, how To solved?
Need Solution
Page generated in 0.35113 seconds with 7 queries
