ASUS ASUS Devices |
04-16-2019, 07:38 | #1 (permalink) |
Insane Poster Join Date: Oct 2014 Location: Gilgit/Pakistan
Member: 2276996 Status: Offline Thanks Meter: 67 | Asus FRP Tool Android 7 Solution v2.1.2 Latest Version FASTBOOT TOOL : - A001 ZU680KL - A002 ZS571KL - L001 ZB690KG - X00AD ZB500KL - X00DD ZC553KL - X00iD ZC554KL - X007D ZB552KL - X009D ZB450KL - X014D ZB452KG - Z00D ZE500CL - Z00ED ZE500KL - Z00LD ZE550KL - Z00MD ZE600KL - Z00RD ZE500KG - Z00TD ZE551KL - Z01B ZC551KL - Z01FD ZS550KL - Z01GD ZS551KL - Z01H ZE553KL - Z01KD ZE554KL - Z01M ZD552KL - Z010D ZC550KL - Z011D ZE601KL - Z012D ZE552KL - Z016D ZS570KL - Z017DB ZE520KL EDL TOOL : - A001 ZU680KL - X00iD ZC554KL - Z00LD ZE550KL - Z01B ZC551KL - Z01FD ZS550KL - Z01H ZE553KL - Z01M ZD552KL - Z011D ZE601KL Download Asus FRP Tool Android 7 Solution RAR |
The Following 12 Users Say Thank You to ahmadalishah031 For This Useful Post: |
05-14-2019, 17:14 | #2 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Share your password here without any blog or site ...! unless forcefully your post will be removed
__________________ To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! Best Wishes : [IMG]****************************/convkey/0fa4/qq0zcyol0fmauiu6g.jpg[/IMG] .:::Roy:::. |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
05-14-2019, 21:22 | #3 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | the password is given in the above linked page: s4tri0-asus The soft decompress itself into a subfolder %temp%\ir_ext_temp_x\AutoPlay\Docs you will see some softs e1 to e9 and fb1 to fb8 for each soft ex or fbx, you can get the related bat by monitoring %temp%\ztmp Examples E1.exe Code: @echo off set ztmp=C:\Users\Aishur\AppData\Local\Temp\ztmp set MYFILES=C:\Users\Aishur\AppData\Local\Temp\afolder set bfcec=tmp49.exe set cmdline= SHIFT /0 @echo off title ASUS FRP EDL Tool v2.0 :start mode 60,20 set cecho=.\app\cecho.exe set com=.\app\sahara.cmd set emmcdl=.\app\emmcdl.exe %cecho% {0f}COMPORT FINDING ..... timeout 2 > nul call %com% IF (%SaharaComPort%) == () ( goto NO ) else ( goto V1 ) echo. :V1 ping localhost -n 1 > nul echo. %cecho% {0f}DEVICE FOUND AT .....{0a} %SaharaComPort% timeout 2 > nul echo. %cecho% {0f}COMPORT FINDING .....{0a} OK timeout 2 > nul echo. echo. %emmcdl% -p %SaharaComPort% -f .\firehouse\x00id.mbn -gpt > nul %cecho% {0a}DOWNLOADING BOOTLOADER ....{0f} OK timeout 2 > nul echo. %emmcdl% -p %SaharaComPort% -f .\firehouse\x00id.mbn -d config -o .\firehouse\x00id > nul %cecho% {0a}CHECKING SECURITY ...{0f} OK timeout 2 > nul echo. %emmcdl% -p %SaharaComPort% -f .\firehouse\x00id.mbn -e config > nul %cecho% {0a}RESETTING SECURITY ...{0f} OK timeout 2 > nul echo. %cecho% {0a}FINISH .... timeout 2 > nul echo. echo. echo. echo. %cecho% {0f} pause GOTO exit :NO cls %cecho% {0c} type .\info\1.txt echo. echo. echo "" Qualocmm QDLoader Comport Not Found "" timeout 5 > nul cls goto exit :exit exit Code: @echo off set ztmp=C:\Users\Aishur\AppData\Local\Temp\ztmp set MYFILES=C:\Users\Aishur\AppData\Local\Temp\afolder set bfcec=tmp49.exe set cmdline= SHIFT /0 @echo off title ASUS FRP EDL Tool v2.0 :start mode 60,20 set cecho=.\app\cecho.exe set com=.\app\sahara.cmd set emmcdl=.\app\emmcdl.exe %cecho% {0f}COMPORT FINDING ..... timeout 2 > nul call %com% IF (%SaharaComPort%) == () ( goto NO ) else ( goto V1 ) echo. :V1 ping localhost -n 1 > nul echo. %cecho% {0f}DEVICE FOUND AT .....{0a} %SaharaComPort% timeout 2 > nul echo. %cecho% {0f}COMPORT FINDING .....{0a} OK timeout 2 > nul echo. echo. %emmcdl% -p %SaharaComPort% -f .\firehouse\x00id.mbn -gpt > nul %cecho% {0a}DOWNLOADING BOOTLOADER ....{0f} OK timeout 2 > nul echo. %emmcdl% -p %SaharaComPort% -f .\firehouse\x00id.mbn -d config -o .\firehouse\x00id > nul %cecho% {0a}CHECKING SECURITY ...{0f} OK timeout 2 > nul echo. %emmcdl% -p %SaharaComPort% -f .\firehouse\x00id.mbn -e config > nul %cecho% {0a}RESETTING SECURITY ...{0f} OK timeout 2 > nul echo. %cecho% {0a}FINISH .... timeout 2 > nul echo. echo. echo. echo. %cecho% {0f} pause GOTO exit :NO cls %cecho% {0c} type .\info\1.txt echo. echo. echo "" Qualocmm QDLoader Comport Not Found "" timeout 5 > nul cls goto exit :exit exit the people like the useless passwords |
The Following 3 Users Say Thank You to :Aishur: For This Useful Post: |
07-31-2019, 14:16 | #6 (permalink) | |
Insane Poster Join Date: Feb 2013
Member: 1880746 Status: Offline Thanks Meter: 17 | Quote:
ADB FINDDING ..... OK List of devices attached G9AZCY02W955DB5 device Brand : asus Model : ASUS_Z017DA Android Version : 6.0.1 Chipset Type : msm8953 CPU Info : arm64-v8a Security Patch : 2016-12-01 Serial No : G9AZCY02W955DB5 Country Code : Hardware : qcom Build No : MMB29P.JP_Phone-13.2010.1612.161-20170205 The directory name is invalid. c:\progra~1\common~1\system\symsrv.dll.000 Access is denied. Incremental : JP_Phone-13.2010.1612.161-20170205 Product device : ASUS_Z017D_1 Boot Serial No : G9AZCY02W955DB5 WAITING FOR BYPASS FRP .... DONE FRP OFF NOW !!!! PRESS BACK ON YOUR PHONE AND COMPLETE SETUP. Press any key to continue . . . done thanks | |
The Following 2 Users Say Thank You to atanniyi For This Useful Post: |
