ASUS ASUS Devices |
01-08-2016, 03:25 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Nigeria Lagos
Member: 1014618 Status: Offline Sonork: 100.1637137 Thanks Meter: 110 | Asus Z00AD FRP (Google Lock ) Remove Helps... |
The Following 2 Users Say Thank You to TBOUY For This Useful Post: |
03-29-2016, 14:20 | #3 (permalink) |
Junior Member Join Date: May 2008
Member: 772992 Status: Offline Sonork: hohuuty Thanks Meter: 6 | I have successfully removed my ZenFone Go Black (Z00VD), hope to help you Be sure to have 50% battery or more Download Recovery.img and Firmware of the same version (Example: You want to install 12.1.0.29 [UL-ZC500TG_ASUS_Z00VD-WW-12.1.0.29-user.zip] Version Of Firmware Then You Should Download 12.1.0.29 recovery.img or upzip recovery.img from file UL-ZC500TG_ASUS_Z00VD-WW-12.1.0.29-user.zip . The Version Of Recovery Image And Frimware Must Be Same!) - Copy recovery image [recovery.img] and the firmware [UL-ZC500TG-XX-X.XX.XX.XX-user.zip] file to Adb folder > C:\adb\ - After you enter the fastboot/Droid Boot, on the adb cmd type: fastboot flash recovery <Recovery Image File Name.img> (Example: fastboot flash recovery recovery.img) - After the recovery flash complete go to "recovery menu" and select on it, after you enter recovery navigate and select "update from adb" - And on adb cmd type: adb sideload <Firmware File.zip> - Wait the for the process to complete the phone (~25min) - You can now select "wipe data/factory reset" (~5min) - when is finish select "wipe cache partition" (~1min) and for the end select "reboot system now" - The Boot process Will be Little Longer After This Process PLease Be Patient (~5min). How to Enter "Recovery Mode" Hold Power button + Volume up You use the Volume Up key to select [Recovery Mode], press the Volume Down to agree. At this point the machine will appear Android exclamation mark on their backs. You hold down the Power finished press the Volume Up, it will appear Recovery mode |
The Following 5 Users Say Thank You to hohuuty For This Useful Post: |
03-30-2016, 13:27 | #4 (permalink) | |
Insane Poster Join Date: Dec 2014
Member: 2307509 Status: Offline Thanks Meter: 42 | Quote:
The Following 2 Users Say Thank You to joven12345 For This Useful Post: |
07-25-2016, 20:49 | #5 (permalink) |
Freak Poster Join Date: Jun 2009 Location: GV, Brazil
Member: 1064466 Status: Offline Thanks Meter: 34 | any solution for Asus zen go x014d |
The Following 2 Users Say Thank You to tipitiboss For This Useful Post: |
12-20-2016, 15:00 | #8 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india kerala,MALAPURAM EDAKKAR
Member: 1224654 Status: Offline Sonork: jaheer Thanks Meter: 61 | anyone have rerset asus zenfone x014d frp reset |
The Following 2 Users Say Thank You to jasheer For This Useful Post: |
02-07-2018, 16:22 | #10 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | ZenPad 10 Android 7.0 Action: Reset FRP Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : PreLoader USB VCOM Port (COM21) Boot mode: Preloader Phone detected...Please wait Sending DA agent, please wait... Using Algo 1. ---------------------------------------------------- BaseBand CPU :MT8163 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 256 KB SDRAM EXT RAM: 2 GB DRAM ---------------------------------------------------- EMMC: (116Gb+16384Mb) SAMSUNG 0x414a4e423452 EMMC FW VERSION: 07:00:00:00:00:00:00:00 EMMC CID: 150100414A4E42 : 000000000000000000 EMMC UA SIZE: 0x3a3e00000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3a4a00000 [14.572 GB] Preloader SEC version: 2 Status: USB_HIGH_SPEED -Reading GPT Drive OK Checking data, wait... Erasing FRP, wait... FRP Reset Done. Wait untill phone will start charging. All done. |
