ASUS ASUS Devices |
10-13-2017, 17:35 | #1 (permalink) |
Major Poster Join Date: Oct 2015
Member: 2472482 Status: Offline Thanks Meter: 7 | enable diag port for asus zenfone 3 ze520kl or ze552kl enable diag port for asus zenfone 3 ze520kl or ze552kl adb devices adb shell su setprop sys.usb.config rndis,diag,adb -unlock bootloader -downgrade to 6.0 2) download recovery and boot img files - under the folder 3) Go to fastboot mode (power + vol up) - flash recovery.img (command: fastboot flash recovery recovery.img) - flash boot.img (command: fastboot flash boot boot.img) 4) reboot to recovery (power + vol down) 5) install update form micro sd card. set the file UL-ASUS_Z017D_1-WW-13.20.10.152-user.zip that you saved earlier 6) wipe cache 7) factory reset 8) flash custom recovery (twrp) 9) root enable diag port : adb devices adb shell su setprop sys.usb.config rndis,diag,adb .......................all done..................... Last edited by Nizda Mobile; 11-16-2017 at 21:39. Reason: Remove Contact |
The Following 2 Users Say Thank You to haithem gs For This Useful Post: |
11-14-2017, 01:44 | #3 (permalink) |
Junior Member Join Date: Nov 2017 Location: USA
Member: 2776126 Status: Offline Thanks Meter: 0 | Hi yes, your method works, it works to enable the diag mode (Windows detect the COM port) but this method for some reason which currently I dont know it doesnt work to repair or modify the IMEI (using any box e.g miracle or falcon). This is very rare because the port is detected and I suposse most of us search how to enable the diag mode is to repair or modify the IMEI of our asus phone ( in this case ZE520KL ). If you could repair the IMEI, could you show us how to do it? please |
01-07-2018, 06:57 | #4 (permalink) | |
Freak Poster Join Date: Apr 2013
Member: 1912082 Status: Offline Thanks Meter: 46 | Quote:
Last edited by ...:::::NP™:::::...; 03-04-2018 at 08:55. Reason: image has been resize | |
02-09-2018, 19:37 | #7 (permalink) |
Insane Poster Join Date: Oct 2010 Location: colombia
Member: 1431187 Status: Offline Sonork: n/d Thanks Meter: 9 | Device Detected... SELinux := Permissive model:= ASUS_Z012D Androids Version:= 6.0.1 Description Version:= OPEN_Phone-userdebug 6.0.1 MMB29M 13.1301.1603.53-20170718-F release-keys Platform:= msm8953 [ qcom ] [ ] Baseband:= M3.10.47.3.CSC-Libra_080001 Security Patch := 01-03-2016 Simstatus:= ABSENT,ABSENT BusyBox version := 1.21.1 ANDROID-ID = H3AZCY00W086DKM_0000DB7860 type1 root exploit possible. SU Version..su: invalid uid !! NOT ROOTED !! NO SU PERMISSION RE ROOT DEVICE OR GRANT/ACCEPT PERMISSION... Starting All QCOM IMEI Repair... IMEI-1 := 359052070825003 IMEI-2 := 359052070825741 IMEI-1 Read-Only Fail to Write... !!! FAIL !!! Total Time Take...00:00:22 Log Saved |
