ASUS ASUS Devices |
02-02-2016, 11:59 | #1 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Guide: Zenfone2, Stuck in Logo, How Put in Recovery 1) Enteryng in Recovery Mode: 1. Turn off you Zenfone 2 2. Hold Power button + Volume up 3. When the phone is vibrating release power button 4. You can select Normal boot or Recovery boot by pressing Volume up/down button.. To enter Recovery mode choose recovery boot. 5. Then you will see sleeping android robot. Press power button + Volume up and release the buttons. 6. You are now in Recovery mode NOTE: After rooting many users are not able to enter recovery..The dead android bot with error appears...To enter recovery follow these steps: a) Enter recovery as you normally do b) When you see a dead android bot with an error press and hold power button, then (while holding power button) quickly press Vol up and release and then release power button.. NOTE: if always this above steps A and B fail, try in this mode and will work for sure, 100% tested!!! - Connect your device and open you adb foder - In adb send this command: Quote:
IMPORTANT: Of course you know that must need of to have all Drivers Installed before of connect Asus phone to pc, is the very first things you must need, can read and install these Drivers: A) Driver Asus Usb B) Driver ADB After are in Recovery Mode you can Update in various mode, for me the Must easy is in ADB Sideload, done very many times and always with Success 100% Please Not Spam Thread with Thanks Post, respect Rules Forum and Use Only this button in down right corner BR allumts | |
The Following 5 Users Say Thank You to allumts For This Useful Post: |
02-16-2017, 08:56 | #4 (permalink) | |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | Quote:
http://forum.gsmhosting.com/vbb/f977.../#post12344250 | |
The Following 2 Users Say Thank You to Prsctt For This Useful Post: |
