ASUS ASUS Devices |
03-02-2016, 05:53 | #1 (permalink) |
Insane Poster Join Date: Nov 2007
Member: 634596 Status: Offline Thanks Meter: 25 | How To Flash Zenfone Go ZC500TG Helps... |
The Following 2 Users Say Thank You to zerro2665 For This Useful Post: |
03-17-2016, 08:56 | #3 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1001942 Status: Offline Sonork: 100.1581646 Thanks Meter: 28 | |
The Following 3 Users Say Thank You to Guest™ For This Useful Post: |
03-18-2016, 12:18 | #5 (permalink) | |
Freak Poster Join Date: Aug 2011 Location: nepal
Member: 1635479 Status: Offline Thanks Meter: 122 | SD card use 100%% tested me ZC500TG phone Quote:
download from https://www.asus.com/Phone/ZenFone-G...Desk_Download/ ROM file and copy SD card and in put mobile phone then mobile recovery mode ASUS Zenfone Go ZC500TG - How to Hard Reset my phone - HardReset.info then click apply update from external storage then click rom file auto install file | |
The Following 4 Users Say Thank You to deeptamu For This Useful Post: |
03-20-2016, 03:32 | #6 (permalink) |
Crazy Poster Join Date: Mar 2016
Member: 2548422 Status: Offline Thanks Meter: 11 | Follow this link http://boycracked.com/tag/unbrick-as...ne-go-zc500tg/ Sent from my Redmi Note 2 using Tapatalk |
The Following 3 Users Say Thank You to kujangsbj For This Useful Post: |
03-30-2016, 01:24 | #7 (permalink) |
Junior Member Join Date: Apr 2007
Member: 484639 Status: Offline Thanks Meter: 6 | Any ZC500TG (Z00VD variant) firmware SP FlashTool Compatible ? I can't flash the zip from recovery due to an unexpected problem. I found a package for zc500tg but wasn't variant specified and right after flashing i've seen that the variant was Z00YD and touchscreen's not working and the worst: volume UP stopped working . Now if i wanna try flash back the signed zip from asus website it's impossible because i can't get into recovery (it needs Volume UP + power for menu), I can't unlock bootloader because it needs Volume UP for oem unlock prompt confimation in order to get a custom recovery on it. Any idea or any way to convert the signed official zip to a spflashtool friendly format ? Thanks and waiting for an advised reply. |
The Following User Says Thank You to h4x7o0r For This Useful Post: |
03-30-2016, 06:46 | #8 (permalink) |
Member: 2548422 Status: Offline Thanks Meter: 11 | Follow instruction on http://boycracked.com/2016/03/09/off...0tg-stock-rom/ |
The Following 2 Users Say Thank You to kujangsbj For This Useful Post: |
03-30-2016, 12:52 | #9 (permalink) |
Member: 484639 Status: Offline Thanks Meter: 6 | Thank you for your reply but i'm not able to use adb sideload (for that it needs the phone to be in recovery and adb sideload selected). As i said before , i can't get into recovery as long as VOLUME UP doesn't work at all. if someone has full backup from a working ZC500TG Z00VD it would be awesome. Does anyone have any idea where are keymapped "buttons" (volume up, down, power ) Is it part of a preloader partition ? When i had Z00VD they were working but after Z00YD looks like only power and volume down are working . It's not physically. Thanks. |
The Following 2 Users Say Thank You to h4x7o0r For This Useful Post: |
04-22-2016, 17:05 | #10 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Zooropa Age: 42
Member: 18832 Status: Offline Thanks Meter: 18 | Did you find backup for Z00VD? I have here one with preloader deleted, so no use for factory methods, fastboot, adb. A backup with any MTK tool would be needed to revive this handset. Any help is appreciated. Thank you. |
The Following 2 Users Say Thank You to lc5829 For This Useful Post: |
05-12-2016, 21:10 | #12 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: A_1st™ Support Age: 38
Member: 758981 Status: Offline Sonork: 100.1592091 Thanks Meter: 232 | Quote:
u will revive ur device again | |
The Following 2 Users Say Thank You to a_1st For This Useful Post: |
10-22-2016, 14:06 | #15 (permalink) | |
Freak Poster Join Date: Apr 2008 Location: Malaysia
Member: 743791 Status: Offline Sonork: Naruto Thanks Meter: 102 | Quote: | |
The Following User Says Thank You to NinjaBoyz For This Useful Post: |
