ASUS ASUS Devices |
10-04-2019, 15:38 | #1 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1783782 Status: Offline Thanks Meter: 0 | ZE551ML, battery connector and track ruined. The phone anyway works: I connect the battery with two jumper since fortunately the are two test points for + and gnd is not a problem, you can connect nearby. But the are also two pins in the battery connector (the two central ones, upper and lower). Probably they give the board signal to understand temperature and level. Infact the phone see the same temperature (2,5°C) and the same battery level (50%) all the time. ANyway you can also charge it, but you don't know the level of the battery ... you know it's charged when the orange led goes off. My problem is to find two points to connect two jumper to the board to give it the missing signal. I find only block schematics, no detailed one. TIA |
