Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 02-26-2017, 09:22   #1 (permalink)
Moderator
sayed tarik's Avatar
Member: 1566464
Sonork: 100.1611207
Thanks Meter: 840
How to Fix Invalid IMEI Problem Xiaomi
Things to do before start :
  1. Windows based OS (7/8/10)
  2. Download IMEI Converter from here.
  3. Download QPST from here.
  4. Download ADB Fastboot driver setup from here.
  5. Download Qualcomm Driver from here.
  6. Download UltraEdit software from here.
Download QCN Files for Xiaomi Devices :
  1. Download QCN file for Redmi 2 /Prime from here.
Steps to Restore IMEI in Xiaomi Mobiles :
Before going to start first download above all required files in your system and install IMEI converter, UltraEdit and QPST in your system.
Follow below steps to solve IMEI error in Xiaomi devices :
  1. Run Minimal ADB and Fastboot setup and following commands to enable diag mode.
    adb shell
    su
    getprop sys.usb.config
  2. Launch IMEI converter and enter Your orginal IMEI number and convert this number in a specific format. Same thing do for slot 2 IMEI and note down these converted string in notepad.
  3. Launch Ultraedit software and open QCN file which you download from above given link.
  4. Find this string in QCN file “08 8A 76 15 02 82 19 52 55” and replace with the number which you convert via IMEI converter tool.
  5. QCN file edit IMEI Restore Xiaomi MIUI 8
  6. Find again for sim slot 2 “08 8A 76 15 02 82 19 52 51” and replace with the string which you convert for SIM 2.
  7. Again launch Minimal ADB and Fastboot and run Following commands.
    adb shell
    su
    dd if=/dev/block/mmcblk0p13 of=/sdcard/modemst1
    dd if=/dev/block/mmcblk0p14 of=/sdcard/modemst2
    dd if=/dev/block/mmcblk0p20 of=/sdcard/fsg
    These commands will create a backup of the existing images.
    dd if=/dev/zero of=/dev/block/mmcblk0p13
    dd if=/dev/zero of=/dev/block/mmcblk0p14
    dd if=/dev/zero of=/dev/block/mmcblk0p20
    reboot
    These commands will wipe off the modemst1 modemst2 and fsg partitions
  8. After that phone restart automattically.
  9. Again follow first step to enable diag mode.
  10. Now run QPST software and select the Ports tab.
  11. You should see the port added automatically
    In case you dont see any port you can use the “Add New Port” button
  12. Now Click on the Start Clients option on the Top Menu bar. and select Software Download.
  13. You will see a Window like this
  14. Click on the restore tab and then browse to the file that you just saved.
  15. Now click the start Button
  16. Once it is done Reboot your system and You should have your IMEI restored.
After following above steps you can restored your IMEI number. We understand the steps are too complex. Soon we come with an easier guide. but as of now you can follow this to restore your IMEI number. Now you don’t face baseband error in your xiaomi phones.
Enjoy Xiaomi services because:
The Following 31 Users Say Thank You to sayed tarik For This Useful Post:
Old 02-26-2017, 11:23   #2 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 147
I had same problem and this post is real 100 % working
The Following 2 Users Say Thank You to kzafquiel For This Useful Post:
Old 04-07-2017, 04:26   #3 (permalink)
Member: 2704008
Help please send me QCN for redmi 2 2014811
The Following User Says Thank You to Hary Iskandat For This Useful Post:
Old 04-07-2017, 08:14   #4 (permalink)
Moderator
Member: 1566464
Sonork: 100.1611207
Thanks Meter: 840
here your qcn file enjoy
The Following 7 Users Say Thank You to sayed tarik For This Useful Post:
Old 05-17-2017, 06:57   #5 (permalink)
Member: 1988630
Sonork: 100.1664547
Thanks Meter: 299
this method work on redmi note 3 ?
Old 05-18-2017, 07:57   #6 (permalink)
Moderator
Member: 1566464
Sonork: 100.1611207
Thanks Meter: 840
bro you try this method
Old 09-09-2017, 12:43   #7 (permalink)
Member: 2140916
where do you get 08 8A 76 15 02 82 19 52 55 and 08 8A 76 15 02 82 19 52 51
becaous the convert is not like that
Old 09-29-2017, 12:45   #8 (permalink)
Member: 1599104
Thanks Meter: 6
Need Mi Note 4 QCN File. Baseband Unknown. please give me link
Old 11-17-2017, 10:39   #9 (permalink)
Member: 858464
Sonork: amit
Thanks Meter: 22
can it work on mi hm 1lte
Old 12-09-2017, 11:47   #10 (permalink)
Member: 2729813
Thanks Meter: 9
Qcn for Redmi 4 ***** please
Sent from my Moto G (5) using Tapatalk
Old 01-04-2018, 12:21   #11 (permalink)
Member: 2184561
very very thanks bro work...
Old 01-30-2018, 05:24   #12 (permalink)
Member: 2804965
Thanks Meter: 4
ill try my master,thanks for file and tools,good job
Old 04-15-2018, 01:01   #13 (permalink)
Member: 2393189
Thanks Meter: 4
I have a Mi6, Locked Bootlaoder and IMEI Null, How can we recovery imei ? Software version miui 9 downgrade miui 8 but IMEI null bootloader locked please help me
The Following 3 Users Say Thank You to mpayaz50 For This Useful Post:
Old 06-03-2018, 11:36   #14 (permalink)
Member: 2384127
Thanks Meter: 2
I need qcn for mi mix 2.
Old 06-05-2018, 09:08   #15 (permalink)
Member: 237628
Sonork: 100.1668254
Thanks Meter: 136
mi max 2 how to fix ime problem any one help me plz argent
The Following 4 Users Say Thank You to ss.com For This Useful Post:
Page generated in 0.35623 seconds with 7 queries
