Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi
Old 06-07-2018, 22:38   #16 (permalink)
Member: 2842248
Wow this is wonder for me..thanks brother
Old 06-25-2018, 20:54   #17 (permalink)
Member: 2753464
Thanks Meter: 4
Umt is only solution for mi max 2 first reset efs with umt qc fire in edl mode after that open diag mode via dialing code *#*#717717#*#* and then repair imei after write working qcn your problem solve.
Old 06-30-2018, 10:46   #18 (permalink)
Member: 2753464
Thanks Meter: 4
Goto umt qc universal tab for repair imei for mi max 2.
Old 07-06-2018, 15:15   #19 (permalink)
Member: 2753464
Thanks Meter: 4
Goto umt qc universal tab for repair mi max 2 imei repair.100% working solution.
Old 07-12-2018, 06:30   #20 (permalink)
Member: 2683963
Brader how to repaire invLid imei redmi note 4g single sim Dior baseband unknown..?
Plz tell me step by step
Thx
Old 08-18-2018, 05:30   #21 (permalink)
Member: 2726199
Some solution to repair imei xiaomi MIX MAX 2 with bootloader blocked in the Umt?
Old 04-28-2019, 16:40   #22 (permalink)
Member: 1442093
Thanks Meter: 3
Hi,need pocophone f1 QCN File. Baseband Unknown. please give me link
thanks
The Following User Says Thank You to gjegos For This Useful Post:
Old 04-30-2019, 06:38   #23 (permalink)
Member: 2727393
Thanks Meter: 12
Not Working
i'm trying many more times but Not Working
Old 08-30-2019, 22:37   #24 (permalink)
Member: 427174
Thanks Meter: 12
It doesn´t work on locked bootloader phones, I have one Redmi 4x with imei 0, I did activate the diag port through the code *#*#13491#*#* but the diag port connect and disconnect every 15 seconds.
Old 09-02-2019, 06:57   #25 (permalink)
Member: 2918930
ill try my master,thanks for file and tools,good job
Old 09-25-2019, 12:48   #26 (permalink)
Member: 2520266
did any good people here for sharing QCN for mi 8 lite platina ?
Old 10-21-2019, 13:14   #27 (permalink)
Member: 2933187
I tried the method many times on RN5 but always fails.
May the problem been hardware??
Sent from my Redmi Note 5 using Tapatalk
Old 11-06-2019, 11:30   #28 (permalink)
Member: 677360
Hola tengo un problema me dice banda base desconocida como puedo solucionarlo
Old 11-06-2019, 11:55   #29 (permalink)
Moderator
Member: 2665389
Thanks Meter: 1,327
Good, please read the rules of the forum, official language to write is English not the native language, thank you very much.
Regards.
Old 11-06-2019, 11:58   #30 (permalink)
Moderator
Member: 2665389
Thanks Meter: 1,327
Good again, as for your problem that with the xiaomi, you should explain or give more details what model it is, if it is a global version or Chinese version, etc., so it can help you much better, what professional tools do you have? I mean, hydra dongle, umt, miracle box, etc.
Regards.
Page generated in 0.35694 seconds with 7 queries
